Need part#'s for timing belt job.
Old Jan 14, 2005 | 11:50 AM
Deano_D aka
Default Need part#'s for timing belt job.
What part#'s do I need to do a timing belt job on my car from this page.
http://www.hondaautomotivepart...+BELT
and this page
http://www.hondaautomotivepart...OSTAT
I have a d16y7 with 74k so I think it is about time.
Old Jan 14, 2005 | 12:03 PM
lowgman's Avatar
Default Re: Need part#'s for timing belt job. (Hondiger)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hondiger &raquo;</TD></TR><TR><TD CLASS="quote">What part#'s do I need to do a timing belt job on my car from this page.
and this page
I have a d16y7 with 74k so I think it is about time.</TD></TR></TABLE>
You'll need #13 (the timing belt itself) on the first page, and #1 on the second page for the waterpump.
Old Jan 14, 2005 | 12:59 PM
alotawatts's Avatar
Default Re: Need part#'s for timing belt job. (lowgman)
Part # 16 tension spring from page 1 is cheap insurance also.
Also consider new cam and crank oil seals ?
Old Jan 14, 2005 | 09:05 PM
Deano_D aka
Thanks guys.
Old Jan 14, 2005 | 09:34 PM
Del Sol SiR's Avatar
as seen here: http://www.slhondaparts.com/br...+BELT
Part Number Description Price You Save Shopping Cart
14400-P2E-004 BELT, TIMING (104RU24 B-333) $21.60 $5.06
14517-PG6-000 BOLT A, TENSIONER $0.43 $0.10
14513-PE0-015 BOLT, TENSIONER (M6) $0.24 $0.06
90011-PG6-004 BOLT, TIMING BELT ADJUSTER SPRING $2.94 $0.69
90007-679-000 BOLT, TIMING BELT COVER A $2.63 $0.62
90031-PT0-003 BOLT-WASHER (8X22) $3.50 $0.82
14111-P2E-A10 CAMSHAFT $235.90 $55.33
11813-P2A-000 CLIP, TIMING BELT COVER $2.15 $0.50
11811-P2A-000 COVER, TIMING BELT (LOWER) $8.10 $1.90
11821-P2E-000 COVER, TIMING BELT (UPPER) $5.60 $1.32
11840-P08-010 COVER, TIMING BELT BACK $16.70 $3.92
11812-PE0-300 GROMMET, TIMING BELT COVER $1.01 $0.24
91213-P2F-A01 OIL SEAL (29X45X8) $2.36 $0.56
14211-P2E-003 PULLEY, TIMING BELT DRIVEN $9.18 $2.15
11833-P08-000 RUBBER, L. BACK SEAL $4.33 $1.02
11832-P28-A00 RUBBER, R. BACK SEAL $5.47 $1.28
11925-P08-000 SEAL A, ENGINE MOUNTING BRACKET RUBBER $2.40 $0.57
11926-P08-000 SEAL, ENGINE MOUNT BRACKET RUBBER (B) $2.40 $0.57
11831-P2A-000 SEAL, RUBBER (LOWER) $5.26 $1.24
14516-P2A-J00 SPRING, TIMING BELT ADJUSTER $3.17 $0.75
14520-P2A-305 TENSIONER SET, TIMING BELT (KOYO SEIKO) $39.41 $9.24
14520-P2A-306 TENSIONER SET, TIMING BELT (NIPPON SEIKO) $39.41 $9.24
and here: http://www.slhondaparts.com/br...OSTAT
95701-06012-08 BOLT, FLANGE (6X12) $0.15 $0.03
95701-06020-08 BOLT, FLANGE (6X20) $0.09 $0.03
95701-06022-08 BOLT, FLANGE (6X22) $0.58 $0.14
95701-06030-08 BOLT, FLANGE (6X30) $0.69 $0.16
95701-06045-08 BOLT, FLANGE (6X45) $0.69 $0.16
95701-06075-08 BOLT, FLANGE (6X75) $0.72 $0.16
19320-P2A-000 CASE, THERMOSTAT $13.50 $3.17
36533-P07-L00 CLAMP, OXYGEN SENSOR $5.37 $1.26
19311-P2A-000 COVER, THERMOSTAT $10.68 $2.50
19315-P08-010 COVER, WATER OUTLET $8.22 $1.93
19500-PE0-000 JOINT, TUBE $4.63 $1.09
91307-PN3-000 O-RING (17.8X1.4) $0.99 $0.23
91314-634-000 O-RING (27.6X4.1) $1.63 $0.39
91307-PJ7-003 O-RING (9.5X1.5) $0.94 $0.23
19222-P08-004 O-RING, WATER PUMP (YAMADA) $2.47 $0.58
19505-P2A-000 PIPE, CONNECTING $28.12 $6.60
19305-PT0-000 RUBBER, THERMOSTAT MOUNTING $2.34 $0.54
37870-PJ7-003 SENSOR ASSY., TW $25.62 $6.01
37760-P00-004 SWITCH ASSY., THERMO (A-93) (UCHIYA) $27.68 $6.49
37750-PH2-014 THERMO UNIT $23.27 $5.46
19301-P08-316 THERMOSTAT ASSY. (NIPPON THERMOSTAT) $12.31 $2.89
19200-P2A-A01 WATER PUMP (YAMADA) $56.70 $13.30
Old Jan 15, 2005 | 10:21 AM
Deano_D aka
Default Re: Need part#'s for timing belt job. (DelSolSiR)
Why did you list all those parts?
Old Jan 15, 2005 | 01:50 PM
alotawatts's Avatar
He's showing you part prices....with extra stuff in the list. lowgman answered first with what I think most would agree as basics = belt and pump.
I'm ready to do my D16Y8.....did forum searches.......got the parts....here's my list
Valve cover washer set (cover gasket, plug seals, mtg bolt seals)
Timing belt
Belt tensioner spring (opinions vary on the tensioner itself - I' ll skip it)
water pump
Alternator belt
Cam seal ( I think I have a leaker)
Crank seal ('cause I don't want to get a leak)
Old Jan 15, 2005 | 05:35 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hondiger &raquo;</TD></TR><TR><TD CLASS="quote">Why did you list all those parts?</TD></TR></TABLE>
Hookin' you up with some "Tech"
Old Jan 15, 2005 | 08:50 PM
Deano_D aka
Well thanks guys again I love h-t.
SirFerret
Honda CR-V & Element
Nov 20, 2013 06:01 AM
USDM DC4
Sep 26, 2007 05:55 AM
91accordwagon
May 16, 2007 04:36 AM
MooJenLude
May 3, 2007 02:22 PM
