Can i still use peak and hold injectors if i convert obd0 to obd1?
Old Jan 14, 2005 | 09:36 AM
D.Dappa's Avatar
Default Can i still use peak and hold injectors if i convert obd0 to obd1?
I want to convert my 91 da to obd1 however i have some dsm 450 blue tops i want to use on my turbo set up... can i still use them? as far as i know to convert all i need is a obd0 to obd1 conversion harness like from http://www.boomslang.us a obd1 distributor and a 4 wire o2 sensor, i cant find info about the injectors... i know obd1 cars use saturated injectors so i just wanted to make sure any help would be appreciated
Old Jan 14, 2005 | 10:00 AM
Sonny's Avatar
You can use them.
All Honda ECUs want to "see" a high impedance injector. In the early days, they did this by using a low impedance injector + resistor box. In the 92+ cars, they simply did it with a high impedance injector.
Sonny
tgreaves's Avatar
Default Re: Can i still use peak and hold injectors if i convert obd0 to obd1? (D.Dappa)
Yup.. You just need to run a resistor box which if you were obd0 before you will already have one..
Old Jan 14, 2005 | 10:38 AM
Blown90hatcH's Avatar
If you want to run the DSM injectors, you will need to keep the resistor box in your car. If you ever decide to run OBD1/2 injectors, you will remove the resistor box and solder the 5 wires together or run a junction connector to close the circuit.
https://honda-tech.com/zerothread?id=997093
Jason
http://www.JKObdconversionharness.com
Old Jan 18, 2005 | 06:56 AM
D.Dappa's Avatar
Default Re: Can i still use peak and hold injectors if i convert obd0 to obd1? (Blown90hatcH)
thanks guys at least i know i can save some money in that aspect.
surkitroller
Dec 29, 2009 12:58 PM
racingant
Sep 28, 2005 05:10 PM
rogue3221
Nov 23, 2004 11:36 AM
dpine
Jul 14, 2004 06:19 PM
CimorelliCRX
May 16, 2003 09:01 PM
