EF Hatch QUESTION!
Old Jan 14, 2005 | 03:07 AM
nickeynick's Avatar
Default EF Hatch QUESTION!
what tranny can i put on my d16z?????????????? and how simple is the swap into a EF? i know i'm DUMB! just need help!
Old Jan 14, 2005 | 05:34 AM
civic_jdm's Avatar
whatever cable D series trans you want to use..I recommand the Si trans. The swap is easy..Just a simple pull out drop in....If its an Si its not bad for wiring. Dx/Std. you have Mutli port wiring to do also.. If i were you i would either go Obd1 or Now you can actually get your pm6 Ecu chipped with the one wire vtec engagement.....
Old Jan 14, 2005 | 03:15 PM
thumbtack's Avatar
Default Re: EF Hatch QUESTION! (nickeynick)
I used the stock tranny and converted to OBD1 since I had all the parts anyway, only thing I had to get was a P28 ecu and a conversion harness that you can get for about 100-150$ I went through locashracing.com and got the extra wires already done for me for some extra cash. Saved me the hassle.
Old Jan 14, 2005 | 05:48 PM
Nic's Avatar
Nic
do what I have done to the hatchy
ZC tranny with SI final drive
Old Jan 15, 2005 | 11:24 AM
fastassdx's Avatar
From: Come back next year and Ill put some, eggnog in your face, US
go with an 89-91 Si tranny.
blownintegra
Mar 10, 2010 06:51 PM
mrchevez
Dec 6, 2008 11:42 PM
nicko360
Aug 12, 2007 12:23 AM
pdiggitydogg
Oct 22, 2006 02:56 PM
