Need a hatch diaogram
If your talking about the wiring it sucks cause you gotta unplug it all from by the third brake light and wiper, tie a string to it and pull all the wiring out of the hatch by the hole near the roof. No connector to make things eaiser. You pull the string into it so that the wiring can be pulled back through when your ready. Other than that it's just taking off the hatch shocks and the 4 nuts by the dome light (under/above plastic). Also might want to put some sealer near those bolts when you put a hatch back on.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shorte »</TD></TR><TR><TD CLASS="quote">If your talking about the wiring it sucks cause you gotta unplug it all from by the third brake light and wiper, tie a string to it and pull all the wiring out of the hatch by the hole near the roof. No connector to make things eaiser. You pull the string into it so that the wiring can be pulled back through when your ready. Other than that it's just taking off the hatch shocks and the 4 nuts by the dome light (under/above plastic). Also might want to put some sealer near those bolts when you put a hatch back on.</TD></TR></TABLE>
Did this in 5 minutes @ my local junkyard, easy stuff...
SpeedOFsmell
Apr 27, 2013 03:07 PM
