turbo kits ? want to turbo my 2001 coupe
Old Jan 13, 2005 | 10:29 PM
bigr4sho's Avatar
Default turbo kits ? want to turbo my 2001 coupe
i have a 2001 ex and i want the most reliable turbo kit. I would like to know where i can get cheap but quality turbo kits for the d17a2 motor. Show links or websites and post pics of motors with turbos thank you.
Old Jan 13, 2005 | 10:33 PM
PHOBIA's Avatar
Honda-Tech.com » Search » 894 topics found
» Search Results
Your search for turbo kit returned 894 results.
» New Search
Old Jan 13, 2005 | 10:34 PM
Kyles ej1's Avatar
Default Re: (PHOBIA)
well turbo and reliable dont go together unless u have mad tuning all the time and ****. but if u want a cheap good turbo i suggest u build one yourself. http://www.homemadeturbo.com youll get the idea
Old Jan 13, 2005 | 10:41 PM
''s Avatar
Here's a turbo kit for your 01. It is probably the CHEAPEST and QUALITY and FULLY BOLT on kit for your car. For all 01+. Made by TSI. 6PSI stock boost.
Other than that, you can go cheaper but you will have to custom.
http://www.turbokits.com/civic_turbo_kits.html
Civic Extreme Turbo Kits Include:
- Garrett T25 Turbo w/ Wastegate
- Cast Exhaust Manifold
- Chrome Heat Shield
- Downpipe w/ Gasket
- Map Unit (Black Box)
- TSI Blow Off Valve (BOV)
- TSI High Flow Front-Mount Intercooler
- Polished Aluminum Intercooler Piping
- SS Braided lines for Water Cooling
- SS Braided lines for Oiling
- Return Hose and Fittings for Oil to Pan
- All Hoses & Clamps
- All Necessary Hardware & Fittings
- Generic Install Instructions
Fuel System Option 1:
- 2 Injectors & Interface Block
- TSI Injection Control Unit w/ Turbo Timer
- Injector Control System Settings
Fuel System Option 2:
- APEXi V-AFC II
- APEXi Turbo Timer
- Boost Gauge
For Engines: D17
Boost: 6 PSI
HP Gain: 56% Increase (safely on stock engine)
Turbo Efficiency: 325+ HP
Direct Bolt-On: Yes
Warranty: 5 Year on Cast, 1 Year Accessories
PRICE == $2899.00
Old Jan 13, 2005 | 11:15 PM
DrunknMunky's Avatar
Default Re: (l337hxr)
go to http://www.7thgencivic.com and go to the F.I. section of the forums and viola info on turbo kits. thank me later.
Old Jan 14, 2005 | 12:46 AM
teknoracing's Avatar
Default Re: (93blkej1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93blkej1 &raquo;</TD></TR><TR><TD CLASS="quote">well turbo and reliable dont go together unless u have mad tuning all the time and ****. but if u want a cheap good turbo i suggest u build one yourself. http://www.homemadeturbo.com youll get the idea </TD></TR></TABLE>
This isnt necessarily true. As long as youre not constantly pushing high boost and beating the crap out of your car, you should be good.
Cheap and quality should never be used in the same sentence. Quality can cost money. Sometimes forking over extra cash can save you headaches later. You gots to pay to play.
Old Jan 14, 2005 | 07:46 AM
jdmjohnny's Avatar
Default Re: turbo kits ? want to turbo my 2001 coupe (bigr4sho)
RUUUUDYYYYYYYYYYYYYY
dunerider
Honda Motorcycles
Feb 8, 2007 07:36 PM
crx99000
May 21, 2006 02:22 PM
mrxracing
Oct 11, 2004 12:17 PM
conesmasher
Dec 21, 2003 10:32 PM
civicplaya2k1
Jan 26, 2003 09:07 PM
