oil in my b16 manifold.
Old Jan 13, 2005 | 10:17 PM
PHOBIA's Avatar
Default oil in my b16 manifold.
i keep reading thats its normal, people saying thats its from the pcv valve. well i never had this problem before then i swap in thisnew motor and i kept feeling my throttle sticking so i took off the throttle body to give it a good once over and the whole thing is caked in fresh oil.i have a breather on the valve cover so none of thisshit would be re routed back into the intake? my roomate says its major"builds and races chevys" but i keep reading its no big deal? i mean its there for a reason know all of a sudden with this new motor and it wasnt there before so whats going on? what causes it to do this?
Old Jan 13, 2005 | 10:37 PM
PHOBIA's Avatar
Old Jan 13, 2005 | 10:45 PM
crxh22project's Avatar
Default Re: (PHOBIA)
i just recieved my motor today and i want to know too.
why is there all this oil build up inside kind of smells like gas sticky too.
Old Jan 13, 2005 | 10:47 PM
PHOBIA's Avatar
yeah i just cannot figure it out.it was so bad i could barely open my throttle.it had all caked on and would open.i sprayed it down with carb cleaner but i havent had a chance to check it out yet. im wondering if that magic sea foam will help out at all.
Old Jan 14, 2005 | 08:09 AM
PHOBIA's Avatar
little help
Old Jan 14, 2005 | 08:20 AM
EP3_05's Avatar
Default Re: oil in my b16 manifold. (PHOBIA)
If you are boosted like your sig says then my guess is the oil seals on the turbo are gone and leaking oil into the intake tract.
Old Jan 14, 2005 | 08:28 AM
PHOBIA's Avatar
no boost not yet,not until i can get ,y bar sticker.i have all that **** sitting in my room.i need my bar sticker and then a manifold that TwopointZero scammed me for..i need to figure out all the kinks with this new motor before she see's any boost. and to me this isnt good.
Old Jan 14, 2005 | 08:53 AM
EP3_05's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PHOBIA &raquo;</TD></TR><TR><TD CLASS="quote">no boost not yet,not until i can get ,y bar sticker.i have all that **** sitting in my room.i need my bar sticker and then a manifold that TwopointZero scammed me for..i need to figure out all the kinks with this new motor before she see's any boost. and to me this isnt good. </TD></TR></TABLE>
Sorry about that I just kind of guessed you were boosted So you don't have the PCV hooked to the intake? What kind of substance is it? Oil, carbon??? Try to clean it out and then decarbonize the engine with some seafoam or small amount of water.
Old Jan 14, 2005 | 09:04 AM
ajcrx's Avatar
The oil probably got in there thru the hose that runs from the valve cover to the intake tube. That is what makes a oil catch can nice.
Old Jan 14, 2005 | 09:21 AM
PHOBIA's Avatar
there is no hose going from the valve cover to the intake,i have had a breather on there for the last 2 engines so that it would not be re routed into the motor.its not carbon its pure oil.keep em coming guys
Old Jan 14, 2005 | 09:26 AM
RCautoworks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PHOBIA &raquo;</TD></TR><TR><TD CLASS="quote">there is no hose going from the valve cover to the intake,i have had a breather on there for the last 2 engines so that it would not be re routed into the motor.its not carbon its pure oil.keep em coming guys </TD></TR></TABLE>
Do you have the hose that runs by the injectors ( hooked to the pcv ) and runs to the top of the mani ? If so that's where the oil and fuel are coming from, its all blow by that was in the crank case.
EP3_05's Avatar
How do the spark plugs look? Any oil on them? Is the motor "consuming" oil?
Old Jan 14, 2005 | 11:36 AM
PHOBIA's Avatar
well ****, i checked every thing out.its all good now.i took off the throttle body again to clean up a little and there was no new oil at all.thats odd.oh well thanks a lot guys 4 the help.
ivan93egreppin210
Feb 22, 2008 09:33 PM
bird00420
10
Jul 24, 2007 02:55 PM
boomersz
Feb 6, 2007 08:19 PM
Witty
Aug 6, 2003 07:08 PM
GTEater
Nov 8, 2001 07:49 AM
