suspention for a rear brake conversion
Iam planning a rear brake conversion on my 90 ef want to know if I use the teg trailing arms and caliper do I have to use teg coil-overs or can I use civic coil-overs and shocks and same with the tie bar
thanks for your help
You'll only be swapping out the trailing arm assembly. You're not gonna be messing with the LCA's or suspension.
No, you won't need integra coilovers.
How about this question. I will be installing a b18a into my ef hatch and was wondering if I could install the front coil springs from the teggy into the front of the EF. Along with the usual da/db brake package on the ef.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mntuner2 »</TD></TR><TR><TD CLASS="quote">How about this question. I will be installing a b18a into my ef hatch and was wondering if I could install the front coil springs from the teggy into the front of the EF. Along with the usual da/db brake package on the ef.</TD></TR></TABLE>
90-93 suspension bolts up..There's like one part that doesnt..I forget ..
And all 88-00 civic,and 90-01 integra springs fit...
Not sure about the delsol though ,,never tried it..
Maui Built
Oct 3, 2007 03:05 AM
1JDMDOMINICAN
Sep 29, 2005 06:54 AM
