Can I run 89 octane on a GSR?
Old Jan 13, 2005 | 09:16 PM
lazynok's Avatar
Default Can I run 89 octane on a GSR?
jdm itr compression is at 11.1 and it can run on 91......
d16z6 is at ~9.1 and it can run 87
so usdm b18c1 is at 10.1... in the middle... would 89 run it?
Old Jan 13, 2005 | 09:31 PM
Senbonzakura's Avatar
Default Re: Can I run 89 octane on a GSR? (lazynok)
You can run 89, but don't be cheap. Pay the 91 and feed that geezer correctly.
If you run 89 your car will still run but it might act funny.
I ran 89 and I had VTEC problems.
Old Jan 13, 2005 | 09:36 PM
ProjectDarkBlack's Avatar
Default Re: Can I run 89 octane on a GSR? (Kyo Kusanagi)
the computer will retard the timing if it starts to detonate, but its not designed for 89 and it will not be good for it
Old Jan 13, 2005 | 09:38 PM
jdm phantomx's Avatar
Default Re: Can I run 89 octane on a GSR? (ProjectDarkBlack)
ping ping ping
Old Jan 13, 2005 | 10:05 PM
notmightydx's Avatar
dont b echeap! give the car what you know it like 93! thast what it should get all the time.
Old Jan 13, 2005 | 10:08 PM
You_Get_Vapors
Guest
Posts: n/a
Default Re: (notmightydx)
I Wouldn't.
Old Jan 13, 2005 | 10:40 PM
mkiv98's Avatar
Default Re: (You_Get_Vapors)
sell the GS-R and get an RS
Old Jan 13, 2005 | 10:44 PM
sabotage7's Avatar
Default Re:
i wouldnt, for reasons already mentioned...that, and the owners manual (as well as on the guage cluster) even specifically says premium unleaded fuel only!....ive always used 93 oct, engine is purrrrfect!
Old Jan 13, 2005 | 10:49 PM
CA6VTEC's Avatar
<FONT COLOR="royalblue"> You can run 87/89/etc, if you plan to drive like a normal being, not go into vtec. </FONT>
Old Jan 13, 2005 | 11:29 PM
TeaAddict's Avatar
91 is better of course...
just be safe, and treat your ride right...its only like 10 cents more a gallon...
so thats like a buck... a fillup
you hopefully fillup like once a week...
so thats only 52 bucks a year to keep you car running that much better...
91 octane.
Old Jan 14, 2005 | 01:04 AM
teknoracing's Avatar
Default Re: Can I run 89 octane on a GSR? (TeaAddict)
Dont cheap out. Just put that **** water 91 octane that they give us in cali. I wish we had 94, even 93.
Old Jan 14, 2005 | 05:42 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Can I run 89 octane on a GSR? (teknoracing)
yeah 91 octane is some **** water, never put anything but 93 in my car.
Old Jan 14, 2005 | 06:01 AM
You_Get_Vapors
Guest
Posts: n/a
Default Re: Can I run 89 octane on a GSR? (PatrickGSR94)
93 it is...cheers!
Old Jan 14, 2005 | 07:13 AM
HONDA RR's Avatar
Default Re: Can I run 89 octane on a GSR? (You_Get_Vapors)
You shouldn't have bought a gsr if you plan to use 88 octane, it clearly says on the cluster and on the fuel door to use premium fuel only. Just trade it in or sell it and get a eg civic dx it will serve your surpose since your not into performance.
Old Jan 14, 2005 | 07:19 AM
TeaAddict's Avatar
Default Re: Can I run 89 octane on a GSR? (MITSUBA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MITSUBA &raquo;</TD></TR><TR><TD CLASS="quote">You shouldn't have bought a gsr if you plan to use 88 octane, it clearly says on the cluster and on the fuel door to use premium fuel only. Just trade it in or sell it and get a eg civic dx it will serve your surpose since your not into performance. </TD></TR></TABLE>
easy there pal... he never said he wasn't into performance, he was just trying to be stingy.
Old Jan 14, 2005 | 07:26 AM
LS-lownslow's Avatar
Off topic question: can u ever have too much octane in the car? Down here they sell 103 and 110 at certain gas stations... We use to run it in dirtbikes and our drag car but could it possible hurt a car... i know the 110 is leaded which will hurt o2 sensors correct?
Old Jan 14, 2005 | 07:42 AM
JBBNJ609's Avatar
Default Re: Can I run 89 octane on a GSR? (broken sword)
cheap cheap cheap
Old Jan 14, 2005 | 08:35 AM
SMZ GSR's Avatar
Default Re: (LS-lownslow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LS-lownslow &raquo;</TD></TR><TR><TD CLASS="quote">Off topic question: can u ever have too much octane in the car? Down here they sell 103 and 110 at certain gas stations... We use to run it in dirtbikes and our drag car but could it possible hurt a car... i know the 110 is leaded which will hurt o2 sensors correct?</TD></TR></TABLE>
I can't say it would HURT it because I'm not exactly sure, but the problem with to high of an octane is that it wont all burn off.
DO NOT use 89 for extended period of time. Back when I was looking for my GSR, I found a 95 with about 80k on it. The owner was an older guy who had the maintainence done but ran 89 for as long as he could remember. Car knocked really bad and ran like ****.
Old Jan 14, 2005 | 06:39 PM
lazynok's Avatar
Default Re: (SMZ GSR)
BLAH! I'm not being cheap!!!!!!
the reason is, i just put a b18c1 in my civic.
my car has 3/4 tank full of 87 octane right now... since i wasnt planning on swapping, but i hydrolocked with it almost full.
so now i threw a b18c1 in it (well im doing it right now.. taking a break to eat)... well i wanted to know if i could make it to th gas station and such.
i bought a 102 or 108 octane booster.. but its not much and my engine is almost full... so im guessing it would put me around 90.... so i wanted to know the 89 just to be on the safe side. i hope is enough to get me to the gas station to get some premium.
well noone cares, everyone thinks i'm a cheap **** anyways. blah. i should have just syphoned the 87 out and put some 91 in the tank in the first place..
Old Jan 14, 2005 | 06:53 PM
Mischief_EG's Avatar
Default Re: (lazynok)
when i dropped my b18c in my hatch i had a half tank of 87 in it....i just threw in some octane booster and topped it off with premium....and it ran fine....but thats just me. never use anything other than 91+
dc2415
Apr 24, 2008 03:37 PM
enobiko
Jan 11, 2005 07:22 PM
plan B.
May 28, 2004 08:13 AM
Oh Sohc Slow
Jan 4, 2004 08:46 AM
nerdish
Jul 9, 2001 01:49 PM
