chamber fix
Old Jan 13, 2005 | 05:31 PM
bugster's Avatar
Default camber fix
i have a 89 crx and 89 civic hatch. the crx has adj. coil overs and is so low the camber is rediculous. i bought some camber kits (front and rear). but on the front the upper a arms hit the inner fender wells. so i raised it up as far as the sleeves would go and now theres only like a half in to travel before it hits again. the car doesnt even look that low anymore. is there any other fixes for chamber. i had a shop tell me they bend the arms or something. ive seen adj a arms or a arms with adj ball joint mounts will these still hit?
i want to maybe lower my civic a lil bit ( pretty low with the body kit) but seeing how messed up my crx is i dont know what would be best. i was thinking i need new shocks and struts, i was goin to get some tokicos and maybe a set of springs. how low can i take it before camber is more than -1 degrees?
Old Jan 13, 2005 | 05:36 PM
EL Vap133's Avatar
Default Re: chamber fix (bugster)
I think you mean the "camber" right?
Old Jan 14, 2005 | 07:51 PM
user 98292739's Avatar
get it low and get it alighned(sp?) teh shop fixed everything. i have a 3 inch drop went through brand new tires in 2 months. i learned my lesson alighned(sp?) as soon as you drop!
sleep_Rx
Suspension & Brakes
Jan 9, 2008 05:55 PM
It's*BOLO!!
Dec 8, 2007 04:13 PM
RanCRX
Suspension & Brakes
32
Oct 25, 2007 11:32 AM
Silent Knight
15
Jan 5, 2006 02:04 PM
vitrox
Jul 13, 2004 04:37 PM
