Honda S2000 Honda S2000
Billstein Suspension Q's
Old Jan 10, 2002 | 11:09 AM
itr501's Avatar
Default Billstein Suspension Q's
My bro just got a Billstein Suspension installed on his S, but he seems to be quite uncomfortable with it. He says the tail comes out to easily for his standards. He is a novice so is there anything he can put on or do before he learns how to use oversteer to his advantage?
Old Jan 10, 2002 | 11:36 AM
grippgoat's Avatar
Default Re: Billstein Suspension Q's (itr501)
Stiffer front swaybar (or softer rear). Work with alignment settings.
-Mike
Old Jan 10, 2002 | 02:01 PM
Big Phat R's Avatar
Did he get a 4 wheel alignment done after the install? If not, he should have. Did he lower the car?
Old Jan 10, 2002 | 03:47 PM
itr501's Avatar
He got his suspension aligned, corner weighted, etc. already. Yes he did lower it...thats another thing...it seems like it wasn't even dropped that much...
[Modified by itr501, 12:48 AM 1/11/2002]
Old Jan 10, 2002 | 05:54 PM
Big Phat R's Avatar
He should try raising the car back up to stock height. I've heard that lowering the S2K greatly changes it's handling. Mind you he will have to get it cornerweighted and aligned again.
He might also try lowering the rear tire pressure a bit. Do you know what tire pressures he is running? Is he still on stock rims/tires?
Old Jan 10, 2002 | 09:38 PM
itr501's Avatar
Default Re: Billstein Suspension Q's (Big Phat R)
Yes hes still on stock rims/tires
Old Jan 11, 2002 | 08:00 AM
Spayellows2k's Avatar
I have H&R's which are pretty much the same thing as the Bilstein's. I have the car lowered about an inch from stock. The coilovers can go much lower, but any lower and the alignment is too far out of spec. I had it lowered the whole way for a couple days just to see what it looked like and the handling was herrendous. If you keep em half way between stock and slammed you should be able to maintain most of your original suspension travel, but don't expect the car to handle as well as stock. You could experiment with sway bars, but it won't necessarily solve the problem.
Old Jan 11, 2002 | 11:44 AM
SilverSurfer's Avatar
New User
Your bro wouldnt happen to be Cliff would it?
gwiffer
Suspension & Brakes
Dec 13, 2010 04:20 PM
Shorthand
Suspension & Brakes
11
Oct 8, 2007 04:03 PM
thegooddoctorceretti
Jun 23, 2007 12:05 PM
D-Atk
13
Aug 6, 2005 10:07 PM
jonnybravo
Oct 2, 2002 08:36 AM
