WIRING GURU'S I need your help!!! OBDIIB to OBDI questions...
Old Jan 13, 2005 | 03:22 PM
Richard Noggin's Avatar
From: Good luck to this industry, you're gonna need it.
Default WIRING GURU'S I need your help!!! OBDIIB to OBDI questions...
I need to pick up a starter and a alternator for my engine build/ swap but the parts I want to buy are OBDIIB (00' Civic Si). The car is a 1996 EK and I will be modifying the factory harness for swap.
Engine:
OBDI 95' LS block
OBDI B16 head
I will be purchasing a:
00' Si alternator
00' Si starter
Will either parts have to be manipulated or will there be a wiring problem using those two OBDIIB parts? If so, please explain what I can do OR please link me to something I might have missed.
Thanks guys, sale pending on this information.
-Chris
Old Jan 13, 2005 | 03:27 PM
JDMH22HATCH's Avatar
Default Re: WIRING GURU'S I need your help!!! OBDIIB to OBDI questions... (THEHARDWAYEK)
Any b-series starter should work and I believe you will need an obd2 alternator to use with the obd2 harness. I believe the alternator plug is different between obd1 and obd2. A & B shouldn't matter. Hopefully somebody else will chime in and make sure this info is correct
Old Jan 13, 2005 | 03:29 PM
Default Re: WIRING GURU'S I need your help!!! OBDIIB to OBDI questions... (JDMH22HATCH)
Thanks for your response, I kinda figured on the starter, but better safe than sorry. The bigger concern is with the A vs B as you stated. Thanks again.
Chris
Old Jan 13, 2005 | 03:31 PM
I really don't think the a & b makes a difference in the harness for teh alternator. Try doing a search on part numbers for an alternator @ http://www.hondaautomotiveparts.com for a 96 civic ex and and 99 civic ex to see if the part numbers are the same
Old Jan 13, 2005 | 03:33 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMH22HATCH &raquo;</TD></TR><TR><TD CLASS="quote"> Try doing a search on part numbers for an alternator @ http://www.hondaautomotiveparts.com for a 96 civic ex and and 99 civic ex to see if the part numbers are the same</TD></TR></TABLE>
I didn't think anything about that. Thanks again!
Chris
Modified by THEHARDWAYEK at 7:55 PM 1/13/2005
HondaPartsHero
May 24, 2006 06:47 PM
Richard Noggin
Jan 14, 2005 08:03 PM
AdamITR
Feb 7, 2003 02:35 PM
