Anyone put a crx dash in a civic hb?
Old Jan 13, 2005 | 02:48 PM
DIY_Racing's Avatar
Default Anyone put a crx dash in a civic hb?
I have a 89 civic hatchback DX. No interior. I picked up a crx dash, it all bolts in, but the wiring for the dash doesnt fit the civic. The crx plugs dont go into the civic fuse box. What did you guys do?? Do i use the civic harness, and mod the plugs?
Any help?? I want to get the helms ETM, but i would need one for the crx, one for the civic.
Let me know. Any help is appreciated.
Old Jan 13, 2005 | 03:21 PM
I Want An Si's Avatar
Default Re: Anyone put a crx dash in a civic hb? (DIY_Racing)
use all the wiring from the civic.... the crx is different and pinned differently...
Old Jan 14, 2005 | 06:53 AM
DIY_Racing's Avatar
Default Re: Anyone put a crx dash in a civic hb? (I Want An Si)
I figured it out. I used the civic harness. I removed all the pins from the guage cluster plugs, then plugged them in like the CRX. Everything works perfectly now. Just need to figure out what plug is the defroster, and what plug is the hazard plug and im set.
Any ideas?
Old Jan 14, 2005 | 07:56 AM
the niz jiz's Avatar
im pretty sure theres another thread about this already being talked about
Old Jan 14, 2005 | 08:06 AM
HONDA92HATCH's Avatar
Default Re: Anyone put a crx dash in a civic hb? (N.O.R.E)
3 years ago i traded a 88 si crx for 89 si hatch that had a crx dash in it. It looked damn good ive herd its fairly easy just messy with all the wires
Old Jan 14, 2005 | 09:53 AM
DIY_Racing's Avatar
Thanks for the help. I searched, havent found what i needed.
Ya, it does look really good. The wiring is thorough, not as difficult as some things i have done, but without a manual, it takes some time.
I have everything working so far, except for the defroster and hazard. The plugs are different, and there is different amount of wires for the hazard so it makes it tough.. PLUS i dont know what plug is actually for the defroster or hazard. ahaha.. I might go to a junkyard and look at a civic so i can see what plug is actually for the hazard and what not.
Old Jan 14, 2005 | 11:41 AM
eumoria's Avatar
the only issue I ran into was that the dashboard from a 91 is further out than the 88 hb dash, so the plugs for the defrost, dimmer, etc are really tight making working with it difficult... but it all works, otherwise.
Also the wiring for the clock in the center is already there even in an 88 STD. They just have it plugged into a plastic "dead clip." It's all in tact and plugs right in and works. I <3 Honda
The final issue you'll hit is that the dashboard will only bolt in in 3 places. The bottom bolt behind the center console will not reach because the CRX dash is more "laid back" than the flat HB one. It hard as a rock with 3 bolts so it's no problem.
I'm still using an 89 Si Cluster/Pod (i hate it, it looks bad on the 91 dash)
And no shift boot (boo)
I'm converting the interior over to black (obviously) and already have the black ebrake console, finishing the front technically.
Old Jan 14, 2005 | 12:23 PM
DIY_Racing's Avatar
Default Re: Anyone put a crx dash in a civic hb? (eumoria)
Ya, i just dont know what plugs, on the civic harness are for the defroster and the hazards... As soon as i do that, i can solder on the crx plugs and im good...
I will have pics here soon...
Old Jan 14, 2005 | 02:11 PM
Shaguar47's Avatar
Hmmmm....for some reason I can't remember swapping harnesses with mine, but then again it went so smoothly. I put a 91 crx dash in my 90 civic. Any more questions beside the harness, and I might be able to answer them for ya.
Old Mar 4, 2005 | 12:41 PM
Crx-Ls's Avatar
Default Re: Anyone put a crx dash in a civic hb? (Shaguar47)
there is no harness change needed or should there be any problems with pugs IF and ONLY IF you used the correct year dash. 88-89crx in 88-89 hatch and 90-91 crx in 90-91 hatch. also the dash bolts everywhere EXACTLY IF and OnLY IF you use the appropriate year dash. hope this helps...
Old Mar 4, 2005 | 01:11 PM
kid-honda's Avatar
Default Re: Anyone put a crx dash in a civic hb? (Crx-Ls)
Me and a buddy did it to one of his hatches and it bolted right in, super easy swap.
speedracercivic
Feb 21, 2007 03:46 PM
the1337aaron
Feb 8, 2007 03:39 PM
donaldmejr
Jun 22, 2006 06:46 PM
kender
Aug 28, 2004 07:45 PM
ShagginJet
Sep 24, 2003 08:20 PM
