k20 swap into a del sol
You should try to use the search option first but here's something that might help you out...
http://www.hybrid-racing.com/
why would it be any different then an ek. the del so comes with a b series or some do so i don't think the mounts are going to be any different then the ek ones
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wrecklezz »</TD></TR><TR><TD CLASS="quote">where would i get the motor mounts and is there any other extra part that i need.....</TD></TR></TABLE>
Mounts can be sourced from either Hybrid Racing or Hasport.
This is just a basic guideline, but beside the mounts you will need:
Motor, tranny, ECU (K pro), conversion harness, shifter box / cables, aftermarket fuel rail, custom fuel lines, universal type fuel pressure regulator, custom axles, custom exhaust manifold, and relocate your radiator.
All of this can add up to $8500+ depending on which motor you are starting out with...
gooberguy31
Oct 29, 2009 03:56 AM
autosport7
Apr 29, 2005 06:58 PM
bluedelsol
Jun 3, 2003 06:14 PM
