Suspension & Brakes Theory, alignment, spring rates....
camber kit adj. ???
Old Jan 13, 2005 | 02:28 PM
civic702's Avatar
Default camber kit adj. ???
was wondering if sears auto would be able to adj. my camber kits while doing the alignment or do i need to go somewhere else??? any help thanks.
Old Jan 13, 2005 | 02:38 PM
Zman15's Avatar
Default Re: camber kit adj. ??? (civic702)
What kind is it? They should be able to...just be prepared if they have questions and be sure to inform them that you have one before hand.
Latez,
Paul
Old Jan 13, 2005 | 03:46 PM
civic702's Avatar
Default Re: camber kit adj. ??? (Zman15)
i got the omni version...
Old Jan 13, 2005 | 09:59 PM
RzHybrid510's Avatar
They should be able if they have an alignment gadgets. If not, you can always go to an NTB, Just Tires, etc. Just ask around for prices and pick the best one that suits your needs.
Old Jan 14, 2005 | 10:03 AM
turboman's Avatar
Try to find a place that will let you into the garage and check the numbers for yourself. Get to know the guy doing the work and give him a few extra $$$.
I found such a shop and got to know the guy and he has hooked me up and thrown my car up on the aligments machine for free several times.
If you autox your not gonna get it right the first time.
Old Jan 14, 2005 | 11:15 AM
civic702's Avatar
Default Re: camber kit adj. ??? (turboman)
i dont auto x but i was rotating my tires and noticed that one side of the car is wearing out a lot faster. this is done with 2.5inch neuspeed race springs. does brake rotors also affect the wear on my tires if they havent been resurfaced in a while??? cause when i hit the brakes the steering wheel shakes pretty bad???
Old Jan 14, 2005 | 10:46 PM
CivicEKCP's Avatar
It could affect tire wear due to the fact that they are making the wheels shake because they are warped....you will want to get new rotors or get the ones you have resurfaced. Might also want to replace the brake pads as well so you have a nice even set up.
Tuesdaynightfever
31
May 24, 2006 06:03 AM
droppedakord
Mar 2, 2005 06:49 AM
NytRyder2k1
Jun 3, 2003 10:56 AM
93dx--hatch
Feb 19, 2003 10:01 AM
686
Jan 22, 2003 01:24 PM
