NC garage sale. B16, B18, F22 and D16y8 parts MISC. Skunk2.Civic/accord/interga. 95 OBD1 H22a ecu. M
In a few weeks I will be moving so I need to get rid of all the stuff I have accumilated in the last year. All prices are neg. Can ship but prefer picked up. The sooner you buy the cheaper the
97 Civic EX automatic transmission. Low mileage, brand new solenoids. Includes torque conv. Pulled for a manual conversion/b16 swap.
$200 obo
97 Accord Ex automatic transmission. also low mileage. includes TQ pulled for a manual conversion/Prelude swap
SOLD
92 Civic Si front spindles with SKUNK2 extended wheels studs. Had these on my 92 hatch till i got rear-ended. The studs where tack welded as suggested by Skunk2. Doesn't include caliper/rotor.
$60 obo
JDM 92 Y21 Sir transmission. Used parts tranny. Only grinded in 3rd gear so i pulled it out. Needs to be rebuild but worth the effort.
$350 obo
92-95 Si floor mats (set). darker grey color. In decent condition.
$20 obo
92 JDM SIR II head. P30 head. Needs some work. Missin 4 valves/springs. 90% complete comes with JDM sir gen 1 cams and gears.
$175 obo
92 JDM SIR I camshafts and gears. Pulled from gen 1 donor head. Not as loud as all other b16 cams but JDM b16a vtec cams non the less! $75 obo
94 Integra LS engine complete longblock/transmission. Engine was in a freshwater damanged car. Already dissembled. Sold together for a better deal or sold seperate. $600 obo for all
-PR4complete head/valve train with cams and valve cover $150 obo
-PR4 intake manifold with all sensor/Injectors/fuel rail.$100 obo
-B series throttle body with map sensor $100 obo
-PR4 block/alt brackets $150 obo
-PR4 pistons and rods connected $60 obo
-PR4 oil pan/windage tray/pickup/water pump. $75 obo
-B series intermediate shaft $75 obo
-PR4/ b-series flywheel. Rusted and need some work. Spend $20 and have it machined and your ready to roll $50 obo
-94 s80 transmission. No grinds. needs to be seperated, parts washed and re-filled with Honda fluid.$300 obo
-PR4 starter and alternator $ 30/each obo
- and a few other parts from a pulled swap before the car was crushed.
SOLD
92-95 Civic, 94+ front upper control arms. <U>Stock,spare set lying around. in good shape with bushings and a arms $50 obo</U>
94+ Accord 5 speed pedal set. Great for an accord 5 spd conversion. Paid 85.... $70 obo
95 H22a OBD1 ecu. Perfect for any swapped accord or OBD2 to OBD1 h22 swapped accord. Used and in working order. purchased with entire in dash harness(sold with ecu!) $125 obo
99 Civic Si rods US spec rods/caps/rod bolts and nuts$60 obo
95 Acura LS/PR4 short block Lying around and collecting dust $100 obo
96 Acura LS/PR4 rods4 rods and 5 pistons $80 obo
more parts comming soon and pics soon enough.
Bump if you view. Thanks
Modified by Em0ne at 7:46 AM 1/14/2005
Modified by Em0ne at 7:36 AM 1/24/2005
$200 obo
SOLD
$60 obo
$350 obo
$20 obo
$175 obo
SOLD
Dueceification
Sep 13, 2016 02:15 PM
Em0ne
May 26, 2006 06:14 AM
GS: 99 civic parts, 94+ accord manual pedal set, F22 complete LB, 98 Civic EX trans auto, and more..
Em0ne
Dec 15, 2004 04:35 AM
