Symtoms of bad outer tie rod
Old Jan 13, 2005 | 01:46 PM
peel17's Avatar
Default Symtoms of bad outer tie rod
Does anyone know what are the symtoms of a bad outer tie rod?
Old Jan 13, 2005 | 01:55 PM
Gekko's Avatar
Default Re: Symtoms of bad outer tie rod (peel17)
Any type of shake or vibration could be culprit, but also could be attributed to wheel bearing, cv joint, etc...
Old Jan 13, 2005 | 01:58 PM
IN VTEC's Avatar
Hard to steer, pulling to the side, and following grooves and ruts in the road.
Old Jan 13, 2005 | 02:14 PM
importdude2000's Avatar
Default Re: Symtoms of bad outer tie rod (IN VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC &raquo;</TD></TR><TR><TD CLASS="quote">Hard to steer, pulling to the side, and <U>following grooves and ruts </U>in the road.</TD></TR></TABLE>
dam i thought it was just my es100's
Old Jan 13, 2005 | 02:29 PM
IN VTEC's Avatar
Default Re: Symtoms of bad outer tie rod (importdude2000)
Imagine it 10x worse and not being able to pull it out of the groove easily and that makes it a broken tie rod.
jdmstyleEJ6
Apr 23, 2011 08:10 PM
rasinhell
May 3, 2005 09:23 PM
FLCivic
Sep 26, 2002 05:58 PM
