whats the difference with a stage 1 clutch n stock???
Old Jan 13, 2005 | 01:40 PM
redINTEGRAdriver's Avatar
Default whats the difference with a stage 1 clutch n stock???
whats the difference with a stage 1 clutch n a stock one ?? is it worth the dough?
Old Jan 13, 2005 | 09:58 PM
ek9jdm's Avatar
Default Re: whats the difference with a stage 1 clutch n stock??? (redINTEGRAdriver)
anything is better then stock, yes its worth it
Old Jan 13, 2005 | 10:01 PM
notmightydx's Avatar
hell exedy is even better than stock! its way worth the money. dont be cheap unless you plan on selling it real soon.
Old Jan 14, 2005 | 01:09 AM
teknoracing's Avatar
Default Re: (notmightydx)
Stage one setups usually have stock disc with a stronger pressure plate. Im assuming you mean a kit. I had this on my sentra and it was a stock disc with a pressure plate designed to handle more torque. Stronger pedal feel.
ACT
Old Jan 14, 2005 | 06:10 AM
X2BOARD's Avatar
Isn't Exedy the OEM supplier for Honda stock clutches ?
Old Jan 14, 2005 | 09:05 AM
GsrGilbert's Avatar
Default Re: (X2BOARD)
in nfsu2 it makes u go faster...
yes a aftermarket clutch assembly does have benifits over the stock unit but,
u really should purchase a clutch based on ur setup not just according to stages.
what setup do u have now and what are u planning on?
JDMFreak_DC2
Aug 6, 2009 04:18 AM
dafuzzbudd
13
May 19, 2008 05:55 PM
batboyvaj
Dec 14, 2007 01:39 PM
d16dcoe45
Nov 12, 2006 05:34 PM
johnqt3
Sep 13, 2005 08:20 PM
