Are the ITR pistons FORGED?
Mostly a forced induction use question.
At what EGT or HP level ... do they start to become the "weakest link"?
BTW -- I was under the impression that the "R" pistons are indeed forged, and "D" concurred.
(but maybe he was just distracted because I was test driving his 98 ITR (with the newly installed JDM FD), through the "park".
Next time I'll have to use the big lobes!
no sir, they are cast as all stock hondas are ... except bike pistons.
Greg
Greg
Well, ... I guess if it's worth doing, then it's worth doing right.
an alternative for some meduim boost applications is cermaic coatings..
can help keep some of the heat out of the piston..but it is rec. to do valves and combustion chamber as well...as they are the next in line for melt down..
D
... and yeah, you definatly should have been on the loud pedal...
D
D
About the loud pedal.
1) didn't want to disturb the "locals"
2) didn't want to make a poor impression on the owner by beating it from the get-go.
Thanks Will, that was the one I had in mind!
However, check out one the first lines in this one.
http://autopedia.com/Acura/97_TypeRPowertrain.html
I can tell you that they are not forged.
And the weights of the pistons and rods are usually off a decent amount.
Proof that you can never believe anything you read.
Honda-Tech. hehePeople here are the hands-on type, as well as helpful!
Thanks Guys. /ed
I just noticed (after all these years) that my link says it's for a "1991" ITR.
-- see above quote --
[Modified by zygspeed, 1:06 PM 1/14/2002]
Wonder if the 11:1 JDM ones are forged?
USDM =
Will
USDM =
Will
/me wondering how many cheaper parts the USDM R has in it
mac_24_seven
11
Aug 7, 2007 02:31 PM
