alternator question??? odb0-odb1
Old Jan 13, 2005 | 09:54 AM
ImportPower13's Avatar
Default alternator question??? odb0-odb1
Can I use an odb-1 alternator if my setup is odb-0. It is a 1st gen b16. Thanks
Old Jan 13, 2005 | 10:01 AM
RedRacerCivic's Avatar
Default Re: alternator question??? odb0-odb1 (ImportPower13)
I have a 1992 alternator on my 1991 Si. The only difference is a few more amps and the alternator pully has one more groove. But the 88-91 civic alt. belt will fit with no problem, just make sure that you align the grooves. Other than that, the alt. is plug and plays with no problem. 96-00 alternators have a different shaped plug, therefore will not work.
Old Jan 13, 2005 | 10:02 AM
Default Re: alternator question??? odb0-odb1 (RedRacerCivic)
Now I was talking about a D16z6 alt on my D16a6. You have a B16, not sure if it will be different.
Old Jan 13, 2005 | 10:51 AM
4drEF's Avatar
Keyboard Humorist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedRacerCivic &raquo;</TD></TR><TR><TD CLASS="quote">Now I was talking about a D16z6 alt on my D16a6. You have a B16, not sure if it will be different.</TD></TR></TABLE>
Same amperage as far as I know.
It will work if the connectors plug in.
If you get one from a Y8 you get a few more amps, but you will need to splice in the correct connector.
Old Jan 13, 2005 | 01:45 PM
CRX_Control's Avatar
Default Re: alternator question??? odb0-odb1 (4drEF)
should be able to use it, my alternator came from a mitsubishi,it was on my d15b6(obd0 engine) then i switched my engine to a d16y8 with no problems( converted to obd1 too) . Hope this helps.
Old Jan 13, 2005 | 03:36 PM
-16V-'s Avatar
Default Re: alternator question??? odb0-odb1 (CRX_Control)
Not to jack the thread or anything. But would i be able to use my alternator mounts from my d15b2 on a d16y7?
And same with the thermostat housing on the back part of the block?
Haydon Bailey
Aug 22, 2018 07:24 PM
civic1821
May 14, 2009 07:46 AM
B16A CRX
Jun 17, 2007 11:46 AM
BoRiCuA
May 25, 2006 06:19 PM
jdmCivic925
Aug 24, 2004 11:55 AM
