What Fuel Pressure is Everyone Running ?
I have the basic bolt ons and now a Vortech FPR...just curious what everyone runs at. I think stock is around 50 psi, correct me if I'm wrong.
Thanks in advance.
Thanks in advance.
In stock form with just bolt'ons.. my motor saw little to no gain from fuel pressure changes. If anything, it would make LESS power.
But once I installed the ported head and slightly raised the compression(11:1), the FPR netted almost 5-7whp on the dyno. The motor really liked the extra fuel pressure I gave it(57psi).
Also, on a B20 I just dyno'd this past week, 15 HP and 13-15 TQ was gained by fuel pressure. Yes, it's a big gain.. but I was hella surprised.
It rolled up with 310cc injectors at 45psi... I bumped it to 50psi and the midrange from VTEC on (4800-7000 or so) literally went THROUGH THE ROOF.
That's a perfect example of knowing how important fuel pressure is. All it takes is 3-5psi for a big difference in power output.
Sorry I strayed off topic a bit...
and it WILL trim based on changes in fuel pressure....that is its primary purpose.
its not a "Rumor" at all....
-dw
-dw
I'm obd2, so how to combat the ecu compensating? (And please don't say replace ecu...)
It bases its "long term fuel trim" on O2 readings during closed loop
and modifies open loop operation accordingly.
i cannot base anything on fuel pressure since it cant know fuel pressure.
on me!
now are you guys talking with the vaccume line on with 45~50psi or with the line off.??? just a little lost thats all
[Modified by JDM_DOHC_SiR, 8:31 AM 1/11/2002]
that is why I say "it will trim based on changes in fuel pressure"....not because it reads fuel pressure, but because it reacts to it.
only way around it is w/ an SFC or custom ecu program...an fpr alone will not do it. Yes you will see dyno plots change when you adjust the pressure on the dyno, but I'd bet if you returned after a day or two of driving, you would see the changes go right back....
-davew
davew: you sound like you're very knowledgeable. laymans terms: you know your ****.
always good when H-T gets new recruits that aren't straight outta CSi
for others' sake.
.....ok, then would it be safe to say it's ok to reset the ecu every once in a while to get this long term fuel trim out of the ecu memory?
So is that mean with a FPR alone is not good enough?
How to compensate it with the VAFC?
I am a bit loss here and I will go dyno soon, can someone please explain what I have to do on the dyno with the FPR and VAFC to get the fuel map that I need?
Thanks for all the help sgT, hope I will do good when I finally get to tune my car!!
So is there a max amount of % that I can use the VAFC to lean out?
I mean if I rise the pressure to 55psi and then go -5% on the VAFC, should I rise the pressure to 58psi and then go -10% on the VAFC just to run higher fuel pressure?
Just to run higher pressure? i dont get it.
you cant equate fuel increase to % of the vafc, because that % number is
a percentage of the map sensor VOLTAGE.
Opps, I always think that when you run higher fuel pressure, it mean you are running richer, so I will need to use the VAFC to lean it out!! My bad, just learn something new again today!! Thanks sgT!!
when u increase fuel pressure you do run richer.
but the idea is not tojust increase fuel pressure and then go back and lean everywhere
you want to richen with the fpr, then lean out where needed with the afc.
OK, so just increase the fuel pressure to a point that I won't need to use the VAFC to add any fuel will be the best?
Sorry for all the stupid questions, I have to admit that I don't know **** about fuel tuning!!
