B18B teg motor to a cable tranny?
Thank you guys, that takes a load off my mind. I should have an easier time with this project as long as the cable tranny will go on that b18b motor and it sounds like it does. One thing, I found some lsd conversion kits for around 300 for the cable tranny. Does anyone know of any better deals or which one I should use? That and any recommendations on a clutch that will hold about 250 whp for that cable tranny? Any good/bad experiences with these lsd conversions or clutchs?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civic »</TD></TR><TR><TD CLASS="quote">The flywheel and pressure plate will work but the hydro and cable clutch discs are different.</TD></TR></TABLE>
Actually, the hydraulic clutch disk is the same as a 1992-1993 cable disk.
I assume the cable tranny was originally mounted to a b motor? If so won't your stock mounts work? If not then I don't think the tranny will mount to that motor... Either way http://www.hasport.com/Products/Mounts.htm is what you need (yeah they can be pricy!)
ya i havre a b18a1 from a g2 92 teg...and am swaping it into a g5 civic 92-95...i dont want to spend the 190 on the hasp[ort kit so i tryin to find a way around it...its almost better to sell the cable tranny and buy a hydro for the cost of that kit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drumking15 »</TD></TR><TR><TD CLASS="quote">its almost better to sell the cable tranny and buy a hydro for the cost of that kit</TD></TR></TABLE>
Unless you have to replace that Hydro tranny and then you'll wish you had a cable tranny. LS cable trannies can be had for very cheap(especially 90-91's).
There isn't a way around using a kit. I believe Enjo(don't quote me on that) makes a somewhat less expensive kit.
Phil
Phil
still nolimits kit is 195...full race has it for 180....but thats just insane to pay that much for a ****** steel bracket and 1 mount!
im workin w/ another kid who is goin to fab this all up for me for like 50 bucks...which is by far a lot more reasonable
gsxr1k05
Aug 29, 2006 05:34 PM
