brake light light on cluster on.... causes?
Old Jan 13, 2005 | 08:18 AM
SuicideSlide's Avatar
Default brake light light on cluster on.... causes?
brake light light on cluster on.... causes? Allready checked fluid levels..fine...
what other sources could cause the light to go on?
Old Jan 13, 2005 | 08:21 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: brake light light on cluster on.... causes? (TurbLu)
make sure your e-brake isnt up one click and check if the wire is shorted. it isnt common, but it is possible.
Old Jan 13, 2005 | 08:22 AM
PHOBIA's Avatar
if you cannot figure it out the easiest thing to do would be to remove to bulb in the cluster.
Old Jan 13, 2005 | 08:29 AM
dantastic's Avatar
Default Re: (PHOBIA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PHOBIA &raquo;</TD></TR><TR><TD CLASS="quote">if you cannot figure it out the easiest thing to do would be to remove to bulb in the cluster.</TD></TR></TABLE>
which is illegal and doesnt fix anything.
there is a sensor in the cap of the master cylinder. if you unplug the cap, then your light should go off. if that works, then your master cylinder cap is bad.
Old Jan 13, 2005 | 08:35 AM
bustah49's Avatar
Default Re: (dantastic)
umm...or the brake fluid is low. which could mean that yer brakes are getting worn or you have a leak.
Old Jan 13, 2005 | 08:42 AM
ZacCarter's Avatar
In my 87 prelude if a brake light was out it caused that light to come on, just a suggestion. Also check your master clyinder cap.
oscarlx
Jul 1, 2012 08:54 PM
sirrvanna
12
Aug 13, 2006 04:16 PM
not2fast
May 17, 2006 07:31 PM
AFAccord
Nov 1, 2005 02:25 PM
arren123
Aug 26, 2003 07:53 AM
