HP#'s On Turbonetics Ball bearing T3T04B
Old Jan 13, 2005 | 07:55 AM
Benjithx's Avatar
Default HP#'s On Turbonetics Ball bearing T3T04B
I have one of these and haven't been able to find much info on there abilities. Turbonetics says they will support up to 450HP, But i am not sure.
Wasn't able to find much on them, Doesn't seem to be a popular choice of turbos around here anyway, If someone has one or knows someone who does please explain setup and #'s. Thanks Guys
Old Jan 13, 2005 | 09:14 AM
Benjithx's Avatar
Default Re: HP#'s On Turbonetics Ball bearing T3T04B (Benjithx)
Old Jan 13, 2005 | 10:35 AM
Benjithx's Avatar
no #'s
Old Jan 13, 2005 | 10:48 AM
Boostage's Avatar
Im pretty sure the t04b is not a ball bearing turbo.
Old Jan 13, 2005 | 10:51 AM
Benjithx's Avatar
Default Re: HP#'s On Turbonetics Ball bearing T3T04B (Boostage)
if thats the case i'v been had
either way what can this thing do?
Old Jan 13, 2005 | 10:52 AM
wantboost's Avatar
Who is Mr Robot?
they sell ball bearing t04e's and b's. the power abilities dont change from those of the non-ball bearing t04's. just quicker spool
Old Jan 13, 2005 | 10:59 AM
Benjithx's Avatar
Default Re: HP#'s On Turbonetics Ball bearing T3T04B (wantboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">they sell ball bearing t04e's and b's. the power abilities dont change from those of the non-ball bearing t04's. just quicker spool</TD></TR></TABLE>
Great, i am pretty sure i have a BB-b thanks wantboost
Old Jan 13, 2005 | 11:00 AM
wantboost's Avatar
Who is Mr Robot?
no problem
Old Jan 13, 2005 | 11:12 AM
Boostage's Avatar
Ok I didnt know that
Old Jan 13, 2005 | 11:21 AM
wantboost's Avatar
Who is Mr Robot?
well, its a quasi ball bearing, if you will. turbonetics uses a standard journal bearing on the exhaust side, with a steel (i think) ball bearing on the compressor side
Old Jan 13, 2005 | 05:23 PM
Benjithx's Avatar
come on guys, people have to be running these. What are you making?
Old Jan 13, 2005 | 05:30 PM
wantboost's Avatar
Who is Mr Robot?
i should be running a ball bearing t3/t04e in the next few weeks
Old Jan 13, 2005 | 07:37 PM
Benjithx's Avatar
Old Jan 13, 2005 | 07:38 PM
wantboost's Avatar
Who is Mr Robot?
lol
Old Jan 14, 2005 | 08:10 AM
Benjithx's Avatar
lol
Old Jan 14, 2005 | 11:15 AM
Benjithx's Avatar
this is looking hopeless
Old Jan 14, 2005 | 12:57 PM
wantboost's Avatar
Who is Mr Robot?
ball bearing turbo arent cool anymore unless they are something uber ultra mega technical like the gt series remember. lol
Old Jan 14, 2005 | 01:18 PM
nsxmatt's Avatar
They will run up to 450whp or limit to about 22psi before they like to destruct.
Old Jan 14, 2005 | 01:43 PM
n0body's Avatar
Im using a Turbonetics T3T04B NON ball bearing turbo. Made 321whp, 264trq at 15 psi with my 9:1 cr 84.5mm B18C1. Spools up fairly quick at 2700rpm and reaches full boost at 4200rpm. Great turbo for mid range power, however, it kind of runs out of breath after 7k rpm.
Old Jan 14, 2005 | 02:39 PM
Benjithx's Avatar
Default Re: HP#'s On Turbonetics Ball bearing T3T04B (n0body)
Ok, so do you think i can get to 400 with my setup at 20 or so psi?
Old Jan 14, 2005 | 03:18 PM
Flr Power's Avatar
So far, you have failed to mention what size turbine you have. Is it stage 1-2-3 or 5? What A/R do you have?
3 variations trim of T04B: SS, SV and SH (in order of CFM)
Old Jan 14, 2005 | 04:40 PM
Benjithx's Avatar
Default Re: HP#'s On Turbonetics Ball bearing T3T04B (coocoo32)
that sounds like something i should know, but i don't.
I bought it as a kit from turbonetics
Old Jan 14, 2005 | 05:30 PM
f22b2tdave's Avatar
i run the fmax kit turbo, t3/t4b 57 trim w/stage 3 wheel, my numbers arent crazy, but i have yet to see what it can do in the 15psi range. i do not believe most of these kit turbos, or at least the drag kit turbo's run max efficiency around 15ish, and nothing more than 20 or so. but thats all speculation as i cant attest that ive tried yet. i dont know if this helps at all, just figured id chime in.
dave
Old Jan 15, 2005 | 10:18 AM
Benjithx's Avatar
Default Re: HP#'s On Turbonetics Ball bearing T3T04B (f22b2tdave)
I am tuning w/boost on Monday so we will see what happens
Old Feb 3, 2005 | 09:58 PM
degradated's Avatar
New User
Did you ever dyno the car?
If you have the 15116 b16a civic kit, it comes with a Ball Bearing T3/T04b SuperV trim Stage II .48 A/R turbo. Because of the smaller turbine side, it should be a good match for the 1.6L motor, but probably not make huge numbers on the dyno. I'm guessing about 350whp max (at high boost).... maybe more if tuned super well with AEM or something running over 20 psi. At a standard 8.5 psi on a stock engine it should be in the 220-250whp range with the kit.
Ryan
