installation of NSX front brake calipers on 2001 ITR
Old Jan 10, 2002 | 08:52 AM
01 ITR 757's Avatar
Default installation of NSX front brake calipers on 2001 ITR
I have an opportunity to buy NSX front brake calipers and was wondering what is involved in installing them on front of 2001 ITR. I plan on using my stock 15 inch wheels as well as my Kosei K-1 15 inch x7 inch with 45 mm backset track wheels with this set up.
Old Jan 10, 2002 | 08:53 AM
sgT's Avatar
sgT
Default Re: installation of NSX front brake calipers on 2001 ITR (01 ITR 757)
make sure they are from the right year or your 15s wont fit.
Old Jan 10, 2002 | 10:26 AM
Phoenix_ITR's Avatar
i'm not sure if the calipers bolt right up to the ITR. i believe you'll have to get brackets made for them. someone correct me if i'm wrong...
Old Jan 10, 2002 | 10:39 AM
davew's Avatar
Default Re: installation of NSX front brake calipers on 2001 ITR (delinquent)
correction. you are wrong. They bolt up. depending on the year however you may have to shave the mounting surface a tiny bit to center them properly on the rotor....and as steve pointed out you may have trouble fitting them under your 15"s
-dw
Old Jan 10, 2002 | 11:38 AM
Mike K's Avatar
Default Re: installation of NSX front brake calipers on 2001 ITR (davew)
You need the front rotors from a Legend GS (aka Type 2 Legend).
It works fine. Bolts up.
Old Jan 10, 2002 | 02:51 PM
-dw
lol...thanks for the correction. you learn something new every day.
Old Jan 11, 2002 | 06:24 AM
davew's Avatar
anytime lol
yeah but the nsx ones are much prettier with cooling fins and nsx logo... haahhaa.
-dave w
Old Jan 11, 2002 | 07:34 AM
nsxtcjr's Avatar
New User
He's talking about the rotors and you're talking about the calipers.
Old Jan 11, 2002 | 08:48 AM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
Default Re: installation of NSX front brake calipers on 2001 ITR (Mike K)
nsx zanardi edition calipers bolt onto the stock itr front spindles w/ stock rotors. they fit under 15" kosei's, although i never tried a stock itr wheels on it. this is on yasu, from Racing Craft's itr.
Old Jan 11, 2002 | 10:04 AM
Mike K's Avatar
Default Re: installation of NSX front brake calipers on 2001 ITR (rodney)
another note worth mentioning is that the Legend GS calipers are the same size as NSX.. they don't have the cool NSX logo.. but they are cheaper.
Old Jan 11, 2002 | 11:08 AM
Black R's Avatar
25 Year Member
.....are they both dual piston as well? (I thought I used to know this...)
Old Jan 11, 2002 | 12:36 PM
nsxtcjr's Avatar
New User
The calipers on the Zanardi are the same as the ones on all the other '97+ NSX's.
I thought the Legend calipers are single piston, unlike the NSX...? Anyone know for sure?
Kamikaze_ITR
Sep 27, 2006 09:00 AM
Money Hou$e
May 17, 2003 02:35 PM
Dropspeed
Aug 30, 2002 10:24 AM
done
Feb 1, 2002 05:15 AM
fso_BamBam
Sep 15, 2001 03:43 PM
