Suspension & Brakes Theory, alignment, spring rates....
uneven ride height??
Old Jan 12, 2005 | 11:26 PM
SNsLude's Avatar
Default uneven ride height??
i tried searching around on my topic but nothing really hit the head on the nail to specifics...
my friend and i just finished installing tokico blues and ground controls... when i tried adjusting height by means of counting the perches on the gc sleeve for front and rear, the height is uneven when car is put down....
in other words, for example, my front gc's have 13 perches on each side, but the ride height is like a finger gap different... same problem with the rear, i forget at the moment which was higher or lower, but when the rears were matched by perches, there was like a finger or 2 gap difference after the car was set down...
should i be alarmed by this? should i just measure by perches or measure by certain methods such as "fender to center of rim" to even out the car?... all 4 should be equal in height yes? ive been reading that "fender to center of rim" and "floor to jackstand points" arent really proper ways of measurement... the closest thing to getting accurate adjustment is by perches, but when the perches are matched, there in lies the uneven ride height issue... TIA!!! much feedback pleaseeee
Old Jan 13, 2005 | 05:09 AM
.RJ's Avatar
.RJ
Default Re: uneven ride height?? (SNsLude)
Measure from hub to fender - use a bubble gauge if you want to make sure you've got the ruler vertical
Old Jan 13, 2005 | 11:27 AM
SNsLude's Avatar
Default Re: uneven ride height?? (.RJ)
thanx... any1 else? what about the uneven height when perches are matched?
Old Jan 13, 2005 | 11:31 AM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SNsLude &raquo;</TD></TR><TR><TD CLASS="quote">what about the uneven height when perches are matched? </TD></TR></TABLE>
They wont be - weight distribution isnt perfect l/r f/r
Old Jan 13, 2005 | 11:34 AM
SNsLude's Avatar
cool thanks... so shouldnt be alarmed by it then right?... cuz i was reading from this thread:: https://honda-tech.com/zerothread?id=834761
and the post made by jake (3rd from last post) seems to be against measuring fender to to hub... any more input on this?
Old Jan 13, 2005 | 11:37 AM
.RJ's Avatar
.RJ
For race car setup, yes...... street car, wont matter too much.
Old Jan 13, 2005 | 11:42 AM
SNsLude's Avatar
cool thanks alot man appreciated
Takumi Fujiwara
Suspension & Brakes
17
May 10, 2011 06:01 AM
bopbop93030
Suspension & Brakes
Mar 29, 2009 08:57 AM
Moejos
Suspension & Brakes
Mar 9, 2009 01:11 PM
Siegfried
May 29, 2007 11:21 AM
BDogggUT34
Jun 30, 2005 08:55 AM
