Suspension & Brakes Theory, alignment, spring rates....
Damper setting for less oversteer?
Old Jan 12, 2005 | 08:11 PM
Chiller's Avatar
Default Damper setting for less oversteer?
I have a set of Tein HAs with 10k front and 8k rear spring rates. I am having a lot of oversteer right now especialy as a daily driver it can be dangerous on wet surfaces! Anyway, I'm trying to get the rear to hold the best it can (for daily only ofcourse). What's better softer in front or softer on the rear. Thanks!
Old Jan 13, 2005 | 04:59 AM
rapid_roy's Avatar
Default Re: Damper setting for less oversteer? (Chiller)
Softer in the rear. You can also decrease your lower tire pressure a few psi.
The rest is up to you, I suggest you attend a driving school if you can.
Old Jan 13, 2005 | 06:07 AM
Chiller's Avatar
Thanks for your reply. Driving school is underway, it would really help for these bad conditions on the road.
Old Jan 13, 2005 | 07:45 AM
suspendedHatch's Avatar
Default Re: (Chiller)
When does the oversteer occur? Corner entry, corner exit?
Your rear rates are too high and will always cause oversteer. I suggest putting a lot of weight in the back. Your overall rates are probably too high for rain. Do you only have one set of springs?
What about your swaybars?
Old Jan 13, 2005 | 08:33 AM
.RJ's Avatar
.RJ
Default Re: (shaundrake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shaundrake &raquo;</TD></TR><TR><TD CLASS="quote">Your rear rates are too high and will always cause oversteer.</TD></TR></TABLE>
8k = 448 lbs
Compared to the front rates, no that is not too high and will still understeer in the dry.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote"> I suggest putting a lot of weight in the back. Your overall rates are probably too high for rain. Do you only have one set of springs?
Do not put weight in the back........ that will likely make the problem worse. Those rates arent too high for the rain.
Old Jan 13, 2005 | 11:12 AM
slammed_93_hatch's Avatar
it could be something else back there that is causeing youre car to do this.
Check you RTA bushing, are they stock?
also maybe its somthing your doing, drop throttle braking mid corner, anything to up set the cars balance
Old Jan 16, 2005 | 09:40 PM
travis's Avatar
Based on the equipment you have listed, I do not think the suspension is the reason for the oversteer and I would hesitate to make any major changes to the damper settings.
Another_Si_Guy
Suspension & Brakes
42
May 6, 2016 09:38 AM
phelpsj2
Suspension & Brakes
Jan 15, 2010 07:43 PM
SlowEJ8
Suspension & Brakes
11
May 2, 2009 06:42 AM
jack-gtir
Suspension & Brakes
Sep 20, 2007 07:00 AM
realis9
Suspension & Brakes
Apr 10, 2007 07:40 PM
