changing dizzy on G1 B16. Is it like hot rods with TDC? or just put it on????
Old Jan 12, 2005 | 06:03 PM
tRex99's Avatar
Default changing dizzy on G1 B16. Is it like hot rods with TDC? or just put it on????
Well im changing my Dizzy soon and i just had a ? because its all about timing. Now with hot rods i member i use to line all the marks up before i can take it out then i put the dizzy in. Well with these hondas is it the same? line the crank pulley mark up then put the dizzy on? or do i just pull it off and put it on and its fine just adjust(advance) from the dizzy while screws are loose?
Old Jan 12, 2005 | 06:06 PM
phatrick2332's Avatar
Look at the the end of the dizzy that goes into the head. You will see that it is keyed so it can only go in one way. One side sticks out a lil further than the other. Just look inside the head and see how its lined up, then line up the dizzy the same and slide it in there. Most of the time i just put it up in and rotate it until it pops in place.
Old Jan 12, 2005 | 06:07 PM
untitled's Avatar
Default Re: changing dizzy on G1 B16. Is it like hot rods with TDC? or just put it on???? (tRex99)
the distributor will only go in one way... Just try it youll see...
RanCRX
Nov 10, 2012 04:13 PM
black0hatch
Aug 27, 2009 04:45 PM
91' LS-VTEC
Jul 20, 2008 11:47 AM
classciv
12
Apr 16, 2006 06:20 AM
nautica_t
Dec 1, 2005 08:03 AM
