97-98 ITR lift duration cam specs????
Im considering purchasing these because they are cheaper than ctr's.Is it a noticable power increase with the civic type r cams or 00-01 itr cams.Anyone know the specs on them and the difference between the two?
As far as I know the intake cam on that year is different than the ctr intake cam. 2000+ itrs have the same intake and exhaust cams.
http://www.nof3ar.cjb.net/ Thats a site with info on the ctr. Scroll down near the bottom and there is a list containing " b series engine specs" that has all the cam info for all the b series motors
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by narib2oo1 »</TD></TR><TR><TD CLASS="quote">Im considering purchasing these because they are cheaper than ctr's.Is it a noticable power increase with the civic type r cams or 00-01 itr cams.Anyone know the specs on them and the difference between the two?</TD></TR></TABLE>
Search ownz jOO:
» Search Results
Your search for cam specs returned 21 results.
1997-1999 ITR
INTAKE lift - 11.5 mm, duration 240 @1mm
EXHAUST lift - 10.5mm, duration 235 @1mm
2000-2001 ITR
INTAKE lift - 11.5 mm, duration 243 @1mm
http://www.allmotorhonda.com/t...s.htm
Search ownz jOO:
» Search Results
1997-1999 ITR
2000-2001 ITR
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by narib2oo1 »</TD></TR><TR><TD CLASS="quote">Is it just the intake cam that has changed?Has there been proven dyno cam increases?</TD></TR></TABLE>
for 3 measly degrees of duration i don't think anyone has doubted the slight increase in duration will make more power enough to waste money dynoing the cams back to back.
navin
May 27, 2004 03:34 AM
