any place or person that can make me a custom turbo inlet flange? need ASAP
Old Jan 12, 2005 | 03:07 PM
TeamShiftPoint's Avatar
Default any place or person that can make me a custom turbo inlet flange? need ASAP
I need a flange for a custom setup.
if anyone can make or knows a place to buy one, let me know.
I need the turbo inlet flange for a precision sc61 t3/t4 turbo.
these are the requirements I need.
3/4 inch thick
stainless steel
t4 size flange
threaded t3 pattern bolt holes
if you have a mild steel 38mm WG flange, I'll buy one from you too.
Ihave paypal, let me know
thanks
William
teamshiftpoint@ev1.net
Old Jan 12, 2005 | 03:44 PM
ExploitedRacing-HR's Avatar
If you give me a print i can make it.
Old Jan 12, 2005 | 04:00 PM
Ekasey's Avatar
Default Re: (ExploitedRacing)
question why 3/4 thick?
I'll try to get a print/tracing of the turbo tomorrow.
Old Jan 12, 2005 | 04:04 PM
Default Re: (eLusive ek4)
I need a spacer that thick...
got a mini-me ac compatible manifold...
using it in a 00 gsr...keeping the stock rad and condensor...slim fans.
I need the flange to be 3/4" and I will turn it and get it tigged to the manifold flange to drop and position the turbo so it clears everything.
Old Jan 12, 2005 | 05:37 PM
Default Re: any place or person that can make me a custom turbo inlet flange? need ASAP (TeamShiftPoint)
I also need (2) regular 3 bolt exhaust flange with 3.5" diameter hole.
mild steel
3/8 inch or whatever suggest.
Old Jan 13, 2005 | 08:05 AM
ttt
Old Jan 14, 2005 | 09:59 PM
I got the print of the flange...I need to get a hold of a scanner so I can get the pic scanned and uploaded.
any of you have 3/4" stock on hand to make it?
Old Jan 15, 2005 | 02:14 AM
Dont have it on hand but can get it same day.
Old Jan 18, 2005 | 09:49 PM
ok, emailed you the scan of the flange...let me know
Old Jan 19, 2005 | 09:21 AM
Default Flange print
http://img123.exs.cx/img123/50...k.jpg
its a PDF file, so right click and save as a PDF file.
Old Jan 19, 2005 | 10:16 PM
dont understand it fully
Old Jan 20, 2005 | 10:01 AM
understand the scan of the flange?
the flange is from a manifold, it had 2 sets of bolt holes (one for t4 and one for t3). I need the flange the same size but with only the t3 holes.
or how to download the PDF?
imageshack only let me upload image files.
just download the jpg file and then rename the file extension to *.PDF
its an acrobat PDF file.
Old Jan 21, 2005 | 07:31 AM
up
McVtec
Aug 6, 2015 11:10 AM
booosting23
Apr 28, 2006 10:28 AM
bambbrose
Apr 10, 2006 07:41 PM
Hoosier Daddy
Feb 3, 2004 06:52 AM
technine
Nov 6, 2002 02:21 PM
