Is the Defi D-gauge Air/Fuel compatible with PLX narrowband to wideband converter?
Old Jan 12, 2005 | 02:11 PM
00BoostedD16's Avatar
Default Is the Defi D-gauge Air/Fuel compatible with PLX narrowband to wideband converter?
Just like it says. On the PLX site it says "The AutoMeter Air/Fuel ratio gauge is designed to read a 0-1V input signal and mapped perfectly linearly with the 20 sweeping LEDs from left to right. Other gauges which can accept a 0-1V input signal (most narrowband gauges are) will also be compatible to work with this converter box. "
Is anyone running the Defi D-gauge with the converter or does anyone know where to find out?
Heres are some links:
Defi D gauge
http://www.defi-shop.com/product/dg/dg_top.html
PLX narrow band to Wideband converter
http://www.plxdevices.com/NB_WB_GaugeConv.htm
thanks
chuck
Old Jan 13, 2005 | 05:32 PM
Anyone? please!
thanks
chuck
Old Jan 14, 2005 | 01:45 PM
eddyboy's Avatar
Default Re: (00BoostedD16)
That would be a negative on that. I had the same idea as you did about 3 months ago. Tried it and didn't work too well.
Old Jan 16, 2005 | 09:05 AM
oh really? aiigh, thanks man
chuck
1.8T_EG
Sep 11, 2002 11:51 AM
Kp_VtekNiks
May 14, 2002 10:40 PM
quick108
Dec 10, 2001 08:16 AM
