What weight oil you use in your EF/CRX?
Old Jan 12, 2005 | 12:11 PM
MLogan's Avatar
Default What weight oil you use in your EF/CRX?
I have always used 5W-30 in my EG hatch because it is recommended but I just realized that the CRX Helm's only recommends 5W-30 for cold weather.
What does everyone else use, the 10W-30 or 10W-40? I plan on using this car for summer (autox) so it definitely has to stand up to some hot temperatures.
Old Jan 12, 2005 | 12:27 PM
crxgator's Avatar
Default Re: What weight oil you use in your EF/CRX? (MLogan)
5w30 or 10w30 for me...
Old Jan 12, 2005 | 12:33 PM
EP3_05's Avatar
Default Re: What weight oil you use in your EF/CRX? ([crx]Hated it!!!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by [crx &raquo;</TD></TR><TR><TD CLASS="quote">Hated it!!!]5w30 or 10w30 for me... </TD></TR></TABLE>
ditto
Old Jan 12, 2005 | 12:52 PM
highhopes's Avatar
Default Re: What weight oil you use in your EF/CRX? (91civic)
I use 10W-40, even in the winter, because my piston rings are starting to go. I've never had any trouble and my car (90 si hatch, 87k) runs like a dream. I also did the same thing with my wagon (d15b2, 240k) and it's also still going strong.
Adding a higher weight oil is a cheap way to keep oil from getting into the combustion chamber if your piston ring seals are starting to wear. Other options include additives (costs $$) and rebuild (costs time + $$).
Old Jan 12, 2005 | 01:15 PM
Jonathan_ED3's Avatar
I'm well over 160K miles and I still use 5w-30 regularly.
Never have any trouble with consuming it, so I'll stick with it until I do.
Old Jan 12, 2005 | 01:20 PM
Kwicko's Avatar
Default Re: (Jonathan_ED3)
I usually use 10w-40, but where I live (central Texas) it rarely gets below 32F, and often gets above 100F.
Old Jan 12, 2005 | 01:59 PM
Rostr02's Avatar
Default Re: (Kwicko)
10w 30 synthetic
Old Jan 12, 2005 | 02:14 PM
88 rex's Avatar
Default Re: (Rostr02)
5w30 all year round......Valvoline high milage only ........191,000 and still holding oil and running strong.
Old Jan 12, 2005 | 02:36 PM
ls_vtec_crx's Avatar
5w-30 mobile 1 synthetic....just made the switch from 10w-30 this past time i changed the oil...i'll be running that from now on....since it doesnt really get cold in hawaii...
Old Jan 12, 2005 | 04:03 PM
Custom Rex's Avatar
Default Re: (ls_vtec_crx)
castrol 5W-50 syntec in b16 crx
Old Jan 12, 2005 | 04:04 PM
The Hooligan's Avatar
From: spinning DnB till your head explodes,jersey/philly
Default Re: (Custom Rex)
10w-30 pepboys brand biatch
Old Jan 12, 2005 | 05:03 PM
NotoriousEK's Avatar
Default Re: (91siredrex)
10/30, ROYAL PURPLE
Old Jan 12, 2005 | 05:57 PM
MLogan's Avatar
Ok, I will keep using the 5W-30 then. Thanks for the input.
Old Jan 12, 2005 | 06:03 PM
jhota's Avatar
5W-30 Castrol GTX, 250k miles and counting, original pan and head gaskets...
Old Jan 12, 2005 | 06:14 PM
altoid's Avatar
Default Re: What weight oil you use in your EF/CRX? (jhota)
0w-30 all synthetic
RSX_S
May 7, 2008 11:58 PM
islnder102
Oct 12, 2006 06:45 AM
ck123
Jul 3, 2006 07:06 AM
sweetchick69
13
Oct 30, 2005 04:32 PM
K20A2-t
Oct 24, 2003 04:43 PM
