Holes in Rear Bumper
Old Jan 12, 2005 | 11:41 AM
TeaAddict's Avatar
Default Holes in Rear Bumper
why are their holes in the rear bumper? I've seen them on a few cars.
Old Jan 12, 2005 | 11:48 AM
aznballer's Avatar
they are basically diffusers, use for aerodynamics, so wind can go past the car smoother
Old Jan 12, 2005 | 11:50 AM
You_Get_Vapors
Guest
Posts: n/a
Default Re: Holes in Rear Bumper (TeaAddict)
It reduces drag. Instead of air from under the car getting stuck in the bumper. If you had a rear under try like a 350Z or Mercedes you wouldn't need those. Thats why most racecars don't use a rear underspoiler.
Old Jan 12, 2005 | 01:44 PM
redhonda91's Avatar
Default Re: Holes in Rear Bumper (You_Get_Vapors)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by You_Get_Vapors &raquo;</TD></TR><TR><TD CLASS="quote">It reduces drag. Instead of air from under the car getting stuck in the bumper. If you had a rear under try like a 350Z or Mercedes you wouldn't need those. Thats why most racecars don't use a rear underspoiler.</TD></TR></TABLE>
exactly i couldnt said it ne-better...by the way(TeaAddict) thanx for postin my pix in a different thread......
Old Jan 12, 2005 | 01:46 PM
SneezR's Avatar
Default Re: Holes in Rear Bumper (redhonda91)
any side shots of your DA? looks awesome
Old Jan 12, 2005 | 02:15 PM
redhonda91's Avatar
Default Re: Holes in Rear Bumper (SneezR)
thanx...heres a link to see some other shots......
https://honda-tech.com/zero...ge=63
scroll all the way down i'm at the bottom of da page......
Old Jan 12, 2005 | 03:06 PM
ATS*JONES's Avatar
i want to do it to my drag bumper...to actually make it a drag bumper..
Old Jan 12, 2005 | 04:33 PM
1sikgti's Avatar
On my car,94 tegra,to avoid not lookin stock the lower part of the bumper is trimmed off.Looks 100% stock to the untrained eye.
Old Jan 12, 2005 | 05:19 PM
redhonda91's Avatar
Default Re: (1sikgti)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1sikgti &raquo;</TD></TR><TR><TD CLASS="quote">On my car,94 tegra,to avoid not lookin stock the lower part of the bumper is trimmed off.Looks 100% stock to the untrained eye.</TD></TR></TABLE>
Old Jan 12, 2005 | 05:37 PM
1sikgti's Avatar
Default Re: (redhonda91)
not sure if you an see it to well,but you can if you look hard enough.Normal tegra bumper curves down an has a small half circle over the tip of the exhaust. If you look at the drivers side of the bumper you can tell its hollow there.
Weel
10
Oct 7, 2019 03:31 AM
8dxhatchy8
33
May 5, 2016 05:36 AM
Twistid
Jun 4, 2004 05:05 PM
3rdGteg
Nov 2, 2003 08:11 AM
