1990 CRX DX main relay clicking and code 16
Old Jan 12, 2005 | 10:31 AM
Desert_Rex's Avatar
Default 1990 CRX DX main relay clicking and code 16
Recently did an engine swap and now I'm getting a code 16 and the main relay is clicking. Any ideas. I know 16 is fuel injectors and as far as we can tell the circuit is good. Could I have a bad relay, injectors, ECU? I'm stumped. Please help.
Old Jan 12, 2005 | 11:51 AM
Jockobo's Avatar
Default Re: 1990 CRX DX main relay clicking and code 16 (Desert _Rex)
could be some grounding issues...mine in particular was the one that goes on the thermostat housing...did the same clicking thing your talking about...
Old Jan 12, 2005 | 12:00 PM
RCautoworks's Avatar
What does your car do ? Crank over or not even crank at all ? If you cars does not start I am pretty sure you will always throw a code 16 .
Old Jan 12, 2005 | 01:33 PM
Desert_Rex's Avatar
Default Re: 1990 CRX DX main relay clicking and code 16 (90blackcrx)
At first it would start and run but now it won't even turn over.
Old Jan 12, 2005 | 02:20 PM
So it just cranks ? I would pull of the fuel hose and see if your getting fuel pressure. Or just swap out the main relay.
Old Jan 22, 2005 | 01:44 AM
ALLMOTORCRX20's Avatar
The first thing i would do is check if your battery has enough power to turn over the engine. My CRX has no spark and no fuel and it turns over every time. If you car does not turn over, it probably needs a better ground. You might try getting a piece of thing wire and ground the engine to the chassis where there isnt paint.
You said the relay was clicking. I had this same thing on my 92 hatch and i replaced the relay and it worked fine. You might wanna try and borrow a relay from someone whose car is working that way you wont buy it and later find out it wasnt the relay.
whiteformula98
12
Jul 29, 2015 12:58 PM
project91crxsi
Jan 8, 2011 12:56 PM
mass-hatch
Jun 16, 2009 03:44 AM
BCrawford
12
Apr 6, 2005 10:54 PM
hb_guy
Jan 26, 2005 02:56 PM
