00 Civic SI & DSM Injectors
Old Jan 12, 2005 | 06:19 AM
dragnsi's Avatar
Default 00 Civic SI & DSM Injectors
I currently have a 00 civic si and i am looking into purchasing a vtec controller. Would it be worth my while to install 390cc or 450cc DSM injectors in my car. Do I need the resistor box for this application. The SI is a non-boosted engine.
Old Jan 12, 2005 | 11:51 AM
X2BOARD's Avatar
Why do you need such big injectors ? Turbo ?
If you're n/a... stick w/ the stockers unless you have some major mods.
And just for your knowledge, yes, you'd need a resistor box for the dsm's.
Old Jan 13, 2005 | 02:35 AM
dragnsi's Avatar
Default Re: (X2BOARD)
I was figuring that the 390cc injectors with a fields vtec controller set for -30% would turn them into about 270-300cc and that would be a nice little performance gain while using a throttle body spacer with plans of upgrading to internal mods and eventually a turbo app. Then I would already have the injector setup needed.
What do you think or
Old Jan 13, 2005 | 05:33 AM
EE_Chris's Avatar
Default Re: (dragnsi)
Def
It doesn't work the way you're thinking....just do the injector swap when the time calls for it.
I mean, why not install the Fields controller and just up the fuel %?
NAlover
Jun 15, 2006 12:52 PM
1baddcivicsi
Jun 1, 2006 10:50 AM
top end tuner
May 25, 2006 04:20 PM
FBP Si 2000
Dec 14, 2003 10:56 PM
matt j
Jul 4, 2003 11:43 AM
