Acura NSX Honda / Acura NSX 1990 - 2005 || Honda / Acura NSX 2017 -
NSX DOHC
Old Jan 12, 2005 | 05:38 AM
sockvtec's Avatar
Default NSX DOHC
i know the NSX has DOHC, but it is a V6 and since i dont know anything bout V engines, i was wondering if it had 2 cams per 3 cylinders, or just 1 per set of 3 cylinders....im not a noob for 4cyl, just a noob for V6
Old Jan 12, 2005 | 07:16 AM
Knightsport's Avatar
El Chico
25 Year Member
Community Builder
Community Influencer
Default Re: NSX DOHC (zoomzoom92)
Dual overhead cam usually denotes two.
Old Jan 12, 2005 | 08:12 AM
DCApex8's Avatar
Default Re: NSX DOHC (Knightsport)
Yeah, he's asking, I think, if its two cams per head (I assume the NSX engine uses two heads, since its a V6) or if each head has only 1 cam
In which case, I believe that its two per head (per 3 cylinders)
Old Jan 12, 2005 | 10:21 AM
NSX Bob's Avatar
New User
There are two per head. The best way of "dumbing" it down would be this: picture two 3 cylinder engines at an angle that both share one crankshaft. Each 3 cylinder engine needs a head. Each head has DOHC's. One cam controls the intake valves, one controls the exhaust valves.
Old Jan 12, 2005 | 12:31 PM
totsie7944's Avatar
Default Re: NSX DOHC (NSX Bob)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NSX Bob &raquo;</TD></TR><TR><TD CLASS="quote">There are two per head. The best way of "dumbing" it down would be this: picture two 3 cylinder engines at an angle that both share one crankshaft. Each 3 cylinder engine needs a head. Each head has DOHC's. One cam controls the intake valves, one controls the exhaust valves.</TD></TR></TABLE>
good info man I haven't seen you on HT in a while. The R is coming home on Friday! Gotta give it some time to break in and then its hitting the dyno
Old Jan 12, 2005 | 03:48 PM
papa5murf's Avatar
nice explenation..
Old Jan 14, 2005 | 09:30 PM
amgnsx's Avatar
Default Re: NSX DOHC (03s2kblue)
I hope so too. if not. GOD help us!!!
Old Jan 20, 2005 | 12:01 AM
Honda-Tech Balla's Avatar
Team Purple
Default Re: NSX DOHC (amgnsx)
Damn bum jigga, you have an NSX? Good ****
carlosd68
16
Mar 21, 2013 11:04 PM
hpimichael02
Jul 31, 2008 05:29 AM
bsmith100
10
Jun 12, 2008 08:36 PM
rice is nice
May 21, 2005 11:52 AM
MugenPoweredLude
Jul 25, 2003 11:44 AM
