Drive the R once a week
Old Jan 12, 2005 | 05:32 AM
wpsadmin's Avatar
Default Drive the R once a week
Do I need to do any special maintenance if I drive my R once every 7 days?
Right now I oil change it every 3k miles syn oil. My battery usually dies if I don't drive it for 14 days. but 7 days, it seems okay.
Old Jan 12, 2005 | 05:35 AM
Bbasso's Avatar
Default Re: Drive the R once a week (wpsadmin)
As long as you drive it long enough to burn off the moisture that builds up in the crankcase you should be fine.
Rice Is Best's Avatar
only special maintenance you need to do is to keep it from getting stolen. that is all
Old Jan 12, 2005 | 05:46 AM
wpsadmin's Avatar
Default Re: (Rice Is Best)
Thanks
since I asked, can you please tell me when I change front brake pads... besides removing it and put the new ones back in and screw tight.. are there anything else? I need to watch out for, such as brake fluids?
Old Jan 12, 2005 | 05:53 AM
Bbasso's Avatar
Default Re: (wpsadmin)
Don't add brake fluid before you change the pads.
and please pump the brakes before you start to drive after changing them.
Old Jan 12, 2005 | 05:58 AM
wpsadmin's Avatar
Default Re: (Bbasso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso &raquo;</TD></TR><TR><TD CLASS="quote">Don't add brake fluid before you change the pads.
and please pump the brakes before you start to drive after changing them.</TD></TR></TABLE>
what does the pumping do? Must I do it?
Old Jan 12, 2005 | 06:04 AM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wpsadmin &raquo;</TD></TR><TR><TD CLASS="quote">
what does the pumping do? Must I do it? </TD></TR></TABLE>
It seats the pads against the rotor. Just give it a few pumps until the pedal firms up. You dont have to do it, unless you like running into a curb when you first drive it.
Old Jan 12, 2005 | 06:31 AM
k20z's Avatar
* B A N N E D *
once a week? damn, mines almost everyday
Old Jan 12, 2005 | 06:36 AM
how many miles do u have on that R? im assuming you're not the first owner
Old Jan 12, 2005 | 06:45 AM
Flux's Avatar
Default Re: (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">
It seats the pads against the rotor. Just give it a few pumps until the pedal firms up. You dont have to do it, unless you like running into a curb when you first drive it.</TD></TR></TABLE>
It really has nothing to do with the pads or rotors. After changing pads you will have compressed the piston to get the new pads into the caliper (watch out for brake fluid coming out of the resevoir becasue of this). You need to pump the pedal several times after the install is complete to get the piston and fluid doing what they need to do again.
Old Jan 12, 2005 | 06:46 AM
wpsadmin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rice Is Best &raquo;</TD></TR><TR><TD CLASS="quote">how many miles do u have on that R? im assuming you're not the first owner</TD></TR></TABLE>
35k miles
ya, I put about 100 miles on it a week. not the first owner.
I have a daily beater that I drive to work each week.
insurance is not bad... $148/month for 2 cars, type r full coverage.
.RJ's Avatar
.RJ
Default Re: (Flux)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flux &raquo;</TD></TR><TR><TD CLASS="quote">
It really has nothing to do with the pads or rotors. After changing pads you will have compressed the piston to get the new pads into the caliper </TD></TR></TABLE>
which presses the pads on to the rotor so you can actually stop......
Old Jan 12, 2005 | 06:49 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wpsadmin &raquo;</TD></TR><TR><TD CLASS="quote">insurance is not bad... $148/month for 2 cars, type r full coverage.</TD></TR></TABLE>
gota love CALI insurance
Old Jan 12, 2005 | 07:05 AM
Flux's Avatar
Default Re: (.RJ)
which presses the pads on to the rotor so you can actually stop...... </TD></TR></TABLE>
Yes indeed. I was just explaining the cause...
Old Jan 12, 2005 | 07:34 AM
SamC's Avatar
Default Re: Drive the R once a week (Bbasso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso &raquo;</TD></TR><TR><TD CLASS="quote">As long as you drive it long enough to burn off the moisture that builds up in the crankcase you should be fine.</TD></TR></TABLE>
How can you tell if there is moisture? and what sign tells you it's burn off?
Old Jan 12, 2005 | 07:43 AM
Lucky-R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wpsadmin &raquo;</TD></TR><TR><TD CLASS="quote">My battery usually dies if I don't drive it for 14 days. but 7 days, it seems okay.</TD></TR></TABLE>there are times that i dont get to drive my car for 2 or 3 weeks myself, but the battery seems to be fine on mine. and yes, i still have the factory battery in there.
Old Jan 12, 2005 | 08:13 AM
Bbasso's Avatar
Default Re: Drive the R once a week (SamC)
It's known as condensation, nothing to see . If the car is driven in operating temps for a while it will turn to steam and evap rather quick.
Old Jan 12, 2005 | 08:19 AM
Dave_B's Avatar
WTF 148 for 2 cars. Damn I have a clean record and still pay 240ish with just the R.
Old Jan 12, 2005 | 08:22 AM
01ITR#173DC2ning's Avatar
From: Somewhere in a DC2.... Supporting the ITR Militia, USA
Default Re: (01PY0559)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01PY0559 &raquo;</TD></TR><TR><TD CLASS="quote">WTF 148 for 2 cars. Damn I have a clean record and still pay 240ish with just the R.</TD></TR></TABLE>
I'm with ya on that all the way..... It's expensive ****.....
But my insurance, parts, and maint. comes before food and water.... lmao
Dammit passwordjdm.com I'm hungry
Old Jan 12, 2005 | 09:44 AM
DragII's Avatar
25 Year Member
Default Re: (01ITR#173DC2ning)
that would be nice to only drive once a week. I need a beater. I put about 250 miles a week on mine.
Old Jan 12, 2005 | 10:23 AM
Kyle244R948's Avatar
Default Re: (DragII)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DragII &raquo;</TD></TR><TR><TD CLASS="quote">that would be nice to only drive once a week. I need a beater. I put about 250 miles a week on mine.</TD></TR></TABLE>
Yeah a beater would be nicccce, I'm putting 300+ miles a week on mine. Man, I hate putting all the miles on it.
Old Jan 12, 2005 | 10:37 AM
Nytemare's Avatar
Default Re: (Kyle244R948)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kyle244R948 &raquo;</TD></TR><TR><TD CLASS="quote">
Yeah a beater would be nicccce, I'm putting 300+ miles a week on mine. Man, I hate putting all the miles on it. </TD></TR></TABLE>
COME ON!!!
Evaluate this my beater cost me $900 (see sig) always runs good, gets like 30-32 mpg everywhere it seems and the insuarnce is NOTHING. I have actually SAVED money, and that's just over a GSR. by insuring the teg 5 or so months a year and the Honda 6-7 months. So over the course I saved around $400 oon insurance alone (I'm 18 so it'd prob be less for older guys). It's on PLPD + comprehensive so I still save TONS of cash.
Not the flashiest things around and chicks don't really like it... but it sure as hell is fun in the snow and my baby stays salt free, clean, and with minimal mileage in the driveway.
Also parts are ALOT cheaper on the Civic which is even more cash for the teg.
Old Jan 12, 2005 | 10:56 AM
wpsadmin's Avatar
Default Re: Drive the R once a week (Lucky-R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lucky-R &raquo;</TD></TR><TR><TD CLASS="quote">there are times that i dont get to drive my car for 2 or 3 weeks myself, but the battery seems to be fine on mine. and yes, i still have the factory battery in there. </TD></TR></TABLE>
yo know, I recently replaced with autozone's Duracell Gold... and once, I didn't drive it for 15 days, the battery die on me..does it mean my car leaks battery?
Old Jan 12, 2005 | 10:57 AM
wpsadmin's Avatar
Remember Type R's legend... so you should def get a cheap beater.. plus I don't wanna show my R at work, no hot chicks there anyways. hehe
Old Jan 13, 2005 | 06:40 PM
k20z's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wpsadmin &raquo;</TD></TR><TR><TD CLASS="quote">Remember Type R's legend... so you should def get a cheap beater.. plus I don't wanna show my R at work, no hot chicks there anyways. hehe</TD></TR></TABLE> u expect ur R to <u> always</u> have low miles?
