Intake Manifold Gasket HELP!!!!
Old Jan 12, 2005 | 04:42 AM
msenra83's Avatar
Default Intake Manifold Gasket HELP!!!!
I got the old engine out and things are really starting to happen now......I just have one concern......When I am swaping the intake manifold, it seems as though there is a hole right on the corner of the head next to the last intake mainfold hole. I heard is is to let some coolant in so that the throttle body does not freeze. Regard less, the holes are actually shaped differently on the 2 engines. On the D16Y7 (the new engine) this hole is round, however on the D15B7 (the old engine) this same hole is like a square shape (not really a square but definitely no where close to being a circle.)
-My question basically is: Which intake manifold gasket should I buy......the one for the d16 or the one for the d15? If you guys could help me out with this I would appreciate it. Thanks once again.
MSenra83
Old Jan 12, 2005 | 05:32 AM
89civicdxracer's Avatar
Default Re: Intake Manifold Gasket HELP!!!! (msenra83)
i would go with the d15 gasket but it really dosnt matter with one u use cuz thay ar almost the same motors
Old Jan 12, 2005 | 06:54 AM
DelSolDon's Avatar
or just cut your own out of cardboard!
ed23cate
Jan 23, 2016 08:29 AM
GsrVtec
Sep 13, 2006 09:53 AM
Shizznaz
Sep 2, 2005 08:07 AM
cpforyou
Jun 26, 2005 02:23 PM
