need help reading & identify keys in Helms manual page 11-15
Old Jan 12, 2005 | 01:21 AM
GsR-Freak's Avatar
Default need help reading & identify keys in Helms manual page 11-15
here is the pdf of section 11-15 for integra 94-01 helms manual, have three questions regard of this digram. Please give me a firm answer, thanx 100000x
*what are the letters (F, A, E) that are in the red cirles represent? especially F
*what are the two solic black cirles in the two small green cirles mean?
*what is the G101 in the Big green circle represents? grouding 101? what does that means?
thanx fellas
Old Jan 12, 2005 | 01:59 AM
GsR-Freak's Avatar
Default Re: need help reading & identify keys in Helms manual page 11-15 (GsR-Freak)
ttt helps..........emergency
Old Jan 12, 2005 | 05:38 AM
JimBlake's Avatar
A, E, & F in the boxes just means that wire is continued somewhere else. Find an arrow pointing upwards with an F, maybe on the following page or 2. That's the continuation of that wire.
Inside the green circles are wires that are actually connected to one another. For example follow the wire upwards from the E in your red circle. It ends with a dot on that brown/black wire, meaning it's actually connected. Look right a bit, where the other vertical wire crosses, there's no dot. That means the wire isn't actually connected.
Just for yuks, look above at the sensor wires. All those black dots are located on the dotted lines, not the solid lines. The dotted lines are the shields around each of those wires. Not the center wire itself.
G101 is a grounding point. Somewhere earlier in the electrical section is drawings of the car, showing where all the grounding points are located.
edit...
Since you asked about components, most are labeled pretty good, like injectors. KS is the knock sensor. CYP, TDC, & CKP sensors are those toothed-wheel sensors down in the base of the distributor (they control spark & injector timing). Wiring harness connectors are labeled like C221 or C101.
The numbers along the left edge are pin numbers at the ECU. There's 4 big plugs, A B C & D. But on my '95 C is not used.
One problem... down near the bottom, I wonder why the EVAP purge control solenoid is labeled 'B18C1 engine' since it's on both engines. It's not marked that way in my Helm book.
Modified by JimBlake at 7:57 AM 1/13/2005
Old Jan 12, 2005 | 06:09 AM
Vu's Avatar
Vu
Are you asking what those components name are? Or just an explanantion of the symbols?
Old Jan 12, 2005 | 10:35 PM
GsR-Freak's Avatar
Default Re: need help reading & identify keys in Helms manual page 11-15 (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">Just for yuks, look above at the sensor wires. All those black dots are located on the dotted lines, not the solid lines. The dotted lines are the shields around each of those wires. Not the center wire itself.
wow you read my mind...i was about to ask another question about the sensors wires of dotted lines... but there you go and nicely gave me an awsome answer..thanx
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vu &raquo;</TD></TR><TR><TD CLASS="quote">Are you asking what those components name are? Or just an explanantion of the symbols?</TD></TR></TABLE>
if you willing to help me out, components and explanation of the symbols. If you know both please help me out, that would be nice.
delus1on
Feb 21, 2007 08:12 AM
Blueallie
Aug 26, 2006 06:31 PM
Drakko
Audio / Security / Video
Aug 22, 2004 01:20 PM
GOLDBERG
Mar 12, 2003 06:39 PM
udctown
Oct 1, 2001 12:12 PM
