replacing e-brake handle and window washer don't spray
Old Jan 11, 2005 | 09:43 PM
ef_you's Avatar
Default replacing e-brake handle and window washer don't spray
firstly, how do I replace my ebrake handle? its green and scratched up..
second, my window washer dont spray. I dont think its the switch because when I pull it to mist the wipers wipe. also, I dont think it's the nozzle because I have lights(previous owner) and they work. also both of them dont spray so I'm thinking there's a leak but I can't see anything. It worked perfectly before. the fluid is there. what to do?
Old Jan 11, 2005 | 09:50 PM
mrspeaker's Avatar
Default Re: replacing e-brake handle and window washer don't spray (ef_you)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ef_you &raquo;</TD></TR><TR><TD CLASS="quote">firstly, how do I replace my ebrake handle? its green and scratched up..
second, my window washer dont spray. I dont think its the switch because when I pull it to mist the wipers wipe. also, I dont think it's the nozzle because I have lights(previous owner) and they work. also both of them dont spray so I'm thinking there's a leak but I can't see anything. It worked perfectly before. the fluid is there. what to do?</TD></TR></TABLE>
The handle just slides off,,Its a bitch but it'll come off..
Is it cold where you live..?maybe the washer fluid has froze up..
If so try some of that stuff that doesnt freeze..
Old Jan 11, 2005 | 11:49 PM
ef_you's Avatar
what you mean slide off? so i should get a screw driver and pry it off or what?
and with the window washer its pretty cold this season but i dont think it will freeze
Old Jan 12, 2005 | 12:30 AM
down_the_hatch's Avatar
Default Re: (ef_you)
yes pry the ************ off, it WILL come off eventually. LOL
Old Jan 12, 2005 | 04:48 AM
my_little_beast's Avatar
Default Re: (uglyasscrx)
i took mine off of my 4 door ek and it was a bitch .not only was it a bitch taking it off but trying to put on the new one was like heart surgery.stock e-brakes rule!
Old Jan 12, 2005 | 05:04 AM
manson's Avatar
Default Re: (my_little_beast)
if you activate the switch for your washers to come on do you even hear the motor whine? What about the rear washer do you hear the motor for that one?
If you don't hear the motor it could have burned out. My experience with the washer motors is they can burn out. what i did to fix mine since the motor for the front washers was not working is switched the two hoses on the washer canisters so the rear washer motor is now my front and the front is the rear. That way i can clean the fronts which is more important in my book. its very easy to do....just look under your car on the washer canister and swap them....just the hoses not the motors.
Old Jan 12, 2005 | 11:32 PM
ef_you's Avatar
i dont have rear squirters
i dont think i hear the motor so what now?
Old Jan 12, 2005 | 11:38 PM
fourthgenhatchB17's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ef_you &raquo;</TD></TR><TR><TD CLASS="quote">i dont have rear squirters
i dont think i hear the motor so what now?</TD></TR></TABLE>
I would give the motor straight 12V from the battery. If it doesnt turn on, replace it.
Old Jan 13, 2005 | 12:49 PM
ef_you's Avatar
where is it? and what are you tellin me to do with it
melloman
Paint and Body
Oct 23, 2008 08:40 PM
Deluzional
Jul 1, 2005 06:07 PM
91integraLSVTEC
May 10, 2005 01:15 PM
joek84
May 11, 2004 06:29 AM
h2392si
May 4, 2003 11:41 AM
