Broken Horn
Old Jan 11, 2005 | 08:40 PM
tspencer227's Avatar
Default Broken Horn
Checked the archives, couldn't find anything there.
I had some work done on the car last week, but nothing that should have affected the horn. Checked the fuses and the wiring, but I can't find out why my horn won't work- (either button on a '00 Base). Anybody have any schematics, or any suggestions to what it could be?
Old Jan 11, 2005 | 10:52 PM
revlimitx04's Avatar
Default Re: Broken Horn (tspencer227)
Explain the work you had done on your car then ask the Question.... If you had front end work done then it could be your actual horns arent connected to the wiring harness... Then agian xplain what work you had done.
Old Jan 12, 2005 | 06:28 AM
Default Re: Broken Horn (revlimitx04)
Front- end alignment work. Shouldn't be anywhere in the vicinity of the horn, right?
Old Jan 12, 2005 | 10:46 AM
fishdude's Avatar
u dont have a car alarm do u?
Old Jan 14, 2005 | 08:45 AM
Default Re: (fishdude)
No car alarm, no aftermarket remote starters or anything like that. It just up and quit working on me.
Old Jan 18, 2005 | 01:12 AM
Default Re: (tspencer227)
Id just tell you to take it back to were they did the alignment and tell em to fix your horn but if it wasnt any were substantial like a dealership i wouldnt even bother... Your horns should be infront of your radaitor, check the harnesses' on those and try to follow the wires as long as you can... Check all the fuses on the horn system... if you cant figure it out screw it, or take it to the dealer.
Old Jan 19, 2005 | 01:55 PM
Default Re: (revlimitx04)
Yeah, I'll borrow a Fluke from work and check it out when I get back on land. Thanks.
91akira
Audio / Security / Video
Sep 16, 2008 06:33 AM
Knight1
Sep 20, 2005 03:05 PM
MestizoRacer310
Mar 16, 2005 08:07 PM
EGRhatch
Jan 14, 2004 04:35 PM
