Quick question, overheating.......
Old Jan 11, 2005 | 08:17 PM
stealth civic's Avatar
Default Quick question, overheating.......
Correct me if Im wrong, but when a thermostat goes bad (stuck closed), the radiator fan will NOT come on, correct? This si on my d15b if theres any confusion. I only ask because before I changed the motor, the fan worked fine, and I have a brand new thermostat, but the upper hose is hot and the lower stays cold.
Old Jan 11, 2005 | 11:17 PM
Default Re: Quick question, overheating....... (stealth civic)
anyone? bueller?
Old Jan 11, 2005 | 11:47 PM
stevescivic's Avatar
bad thermostat. Make sure you're using a honda thermostat. Other ones just don't seem to work as well.
Make sure that there is no air in your system too b/c that would cause the coolant to not circulate. Happened to my friend's accord.
Old Jan 12, 2005 | 12:52 AM
Default Re: Quick question, overheating....... (stevescivic)
This is stuff I know, but what I am asking is will a thermostat that is stuck closed not allow the thermo switch to detect engine temp and therefor turn the fan on. My problem is that the fan isnt kicking on, and I wanted to know if the bad thermostat could be the culprit.
Old Jan 12, 2005 | 07:24 AM
bumpage
Old Jan 12, 2005 | 05:35 PM
oops sorry didn't carefully read your post.
yes the fan temp kick switch is at the bottom of the rad (if i remember correctly). Thus if not hot coolant is circulating in the rad then the fan switch will never trip the cooling fan to come on.
Cheers
Old Jan 13, 2005 | 09:03 AM
Problem fixed, there was just some air in the system, works fine now.
Jamie Steadman
Aug 14, 2015 12:07 PM
torino420
May 5, 2013 08:07 AM
hotcivicsi
19
May 15, 2009 01:54 PM
dth0ng69
Jan 28, 2009 06:19 AM
ludekid4323
Nov 27, 2006 07:36 PM
