Del Sol rear LCA same as 92-95 Civic?
Old Jan 11, 2005 | 08:00 PM
MAD ITR 55's Avatar
Default Del Sol rear LCA same as 92-95 Civic?
I tried searching and I couldn't find anything. I need to know if a rear LCA from a Del Sol will fit on a 92 hatch. I think it will work but I want to double check.
Old Jan 11, 2005 | 08:17 PM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: Del Sol rear LCA same as 92-95 Civic? (MAD ITR 55)
Yes they are the same, 94+ integra are same too. Make sure you get one with a swaybar mounting hole if you have a rear sway bar.
Old Jan 11, 2005 | 08:21 PM
MAD ITR 55's Avatar
Default Re: Del Sol rear LCA same as 92-95 Civic? (94eg!)
I knew they were the same for 92-95 civic and 94+ integra I just wasn't sure about the Del Slow. It's going on a stock dx hatch I'm selling so no need for rear sway bar holes. Thanks...
Old Jan 11, 2005 | 08:49 PM
llxzxll's Avatar
not the same for the ek?
Old Jan 11, 2005 | 08:55 PM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: Del Sol rear LCA same as 92-95 Civic? (llxzxll)
EK rear LCA's are longer & the lower end of the rear shock ("u" shape that bolts to the LCA) is skinnier too. that means no swaping EK rear LCA's or rear shocks.
Sorry
Old Jan 12, 2005 | 05:58 AM
llxzxll's Avatar
so does that mean, i can't use the del Sol VTEC rear discs to swap into an ek?
Old Jan 12, 2005 | 07:11 AM
94eg!'s Avatar
#1 Super Guy
Loved
Yes you can, you just have to use your stock LCA's & struts.
You cannot use the Del Sol 40/40 proportioning valve. You will need one from a 96+ civic (yours might already have it, so search).
I have no idea which E-brake cables you need, so do a search on that.
Wannabe JDM
Jan 31, 2006 05:22 PM
xkwzt21
Suspension & Brakes
Aug 14, 2005 04:39 PM
BrianDelSol
Jul 26, 2004 10:45 AM
topher
Mar 27, 2002 06:40 AM
