Suspension & Brakes Theory, alignment, spring rates....
Preloading omnipowers
Old Jan 11, 2005 | 07:03 PM
sjteg's Avatar
Default Preloading omnipowers
today i preloaded my coilovers but they seem to be way too stiff. The procedure was basically moving the spring and perch up as high as possible with the nut flush with the top of the stud. Next i adjusted the coilovers to the desired height and finally tightened down the nut with all my force.
The problem i think was tightening it too much with the spring as high up as possible. I spoke to omniman about it and he said only .5 inch of preload is needed. So i was thinking of loosening the nut to about .5 from the top? What do you guys think?
Old Jan 11, 2005 | 08:26 PM
sjteg's Avatar
Default Re: Preloading omnipowers (sjteg)
bump
Old Jan 12, 2005 | 02:14 AM
9krpm's Avatar
From: see my earring from a MILE, bling bling, Va, USA
Those coilovers are pretty stiff though. most likely you got the 10k/8k kit? Thats a pretty stiff ride..
Compared to like some Tein SS's where they are like 8k/6k or even with spring rates as low as 3k to make it as close to stock as possible.
Old Jan 12, 2005 | 05:14 AM
.RJ's Avatar
.RJ
why are you preloading them?
You should take the preload out of them, and only add enough to properly corner-weight the car.
Old Jan 12, 2005 | 08:27 AM
sjteg's Avatar
Default Re: Preloading omnipowers (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">why are you preloading them?
You should take the preload out of them, and only add enough to properly corner-weight the car.</TD></TR></TABLE>
i just preloaded them because the instructions said so. I'll try to remove the preload and see what happens.
Old Jan 12, 2005 | 10:49 AM
n1div's Avatar
The sad part is that a majority of the "coilover" owners on this board probably doesn't even know what corner weighting is and even if they do, only a fraction of those ever get it done.
matryx
Suspension & Brakes
10
Aug 24, 2008 09:35 PM
i0o0ll0o0i
Suspension & Brakes
Apr 27, 2006 02:01 PM
crxmadman
Suspension & Brakes
Oct 10, 2005 02:15 PM
aznfab
Oct 22, 2003 12:39 PM
BrandonClaps
25
Aug 11, 2002 10:47 PM
