15's or 16's
Old Jan 11, 2005 | 03:51 PM
eff that ish's Avatar
Default 15's or 16's
im looking at rims right now and i've narrowed the search down to 3 choices. i was wondering what the best rim size for a 95 Civic 4door is?
Old Jan 11, 2005 | 03:53 PM
smokee's Avatar
Default Re: 15's or 16's (eff that ish)
i predict the consensus will say:
15's
Old Jan 11, 2005 | 03:55 PM
sohcvtec1995's Avatar
looks-16, weight (in some cases)-15
also keep in mind that your cars brakeing system is designed to stop a certain size rime. so keep that in mind as well.
Old Jan 11, 2005 | 04:02 PM
lightsleeper's Avatar
Default Re: 15's or 16's (sohcvtec1995)
15's!
Old Jan 11, 2005 | 04:05 PM
SOHC4life 96's Avatar
Default Re: 15's or 16's (lightsleeper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohcvtec1995 &raquo;</TD></TR><TR><TD CLASS="quote">looks-16, weight (in some cases)-15
also keep in mind that your cars brakeing system is designed to stop a certain size rime. so keep that in mind as well.</TD></TR></TABLE>
As well as the gearing. So if you don't get the correct tire size the speedometer will be off.
Old Jan 11, 2005 | 04:18 PM
Revolver's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eff that ish &raquo;</TD></TR><TR><TD CLASS="quote">im looking at rims right now and i've narrowed the search down to 3 choices. i was wondering what the best rim size for a 95 Civic 4door is? </TD></TR></TABLE>
There is no real "best" choice for rim size. Obviously, people are going to put on whatever they want. Some important factors to keep in mind have already been stated. Go with what you want, of course your brakes and gears were meant for one thing. Also, keep things like weight in mind.
Old Jan 11, 2005 | 05:51 PM
Dstretch33's Avatar
Default Re: 15's or 16's (Revolver)
get 20's Yo
Old Jan 11, 2005 | 05:53 PM
civiccpedx's Avatar
Default Re: 15's or 16's (Dstretch33)
i would say stick with 15s they are lighter and closer to stock dimensions so the speedo wont be to far off.
Old Jan 11, 2005 | 05:54 PM
HATCHingMN's Avatar
Default Re: 15's or 16's (civiccpedx)
16 for both look and go
Old Jan 11, 2005 | 06:13 PM
J.EM1's Avatar
Team Purple
Default Re: 15's or 16's (HATCHingMN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HATCHingMN &raquo;</TD></TR><TR><TD CLASS="quote">16 for both look and go </TD></TR></TABLE>
Old Jan 11, 2005 | 06:18 PM
g4hacker's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civiccpedx &raquo;</TD></TR><TR><TD CLASS="quote">i would say stick with 15s they are lighter and closer to stock dimensions so the speedo wont be to far off.</TD></TR></TABLE>
I agree.
Old Jan 11, 2005 | 06:36 PM
Targa250R's Avatar
be professional
What's the "best" wheel size? "Best" for what? Cheap tires? Light weight? Straight line acceleration? Autocrossing? IT racing? Boulevard pimping y0?
I could easily say 13x9 is the "best" wheel size (and it is, actually ), but without telling you what it is "best" for, does it really mean anything?
15s are very common on Civics; they're universal because there is a large selection of affordable performance tires in 15" sizes for Civics. There is also a huge selection of affordable (and not-so-affordable) good-looking wheels available in 15x6.5" and 15x7" with the 4x100mm bolt pattern and the proper offset. There are also several good-looking OEM Honda 15x6" wheels that are popular as well.
Modified by Targa250R at 10:52 PM 1/11/2005
Old Jan 11, 2005 | 06:40 PM
NathanMorris's Avatar
Default Re: 15's or 16's (Targa250R)
15s
Old Jan 11, 2005 | 06:57 PM
eg dash six's Avatar
Default Re: 15's or 16's (92Lx)
i was wondering the same thing.. 15's or 16's.. i ended up purchasing 15's an hour ago.. so i say 15's..
Old Jan 16, 2005 | 07:26 AM
Del Sol SiR's Avatar
Default Re: 15's or 16's (eg dash six)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg dash six &raquo;</TD></TR><TR><TD CLASS="quote">i was wondering the same thing.. 15's or 16's.. i ended up purchasing 15's an hour ago.. so i say 15's.. </TD></TR></TABLE>
I thought you wanted 16"s like you said here : https://honda-tech.com/zerothread?id=1116567
Old Jan 16, 2005 | 07:58 AM
Generic User Name's Avatar
From: Driving your sister in Southern California., ca, duh
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civiccpedx &raquo;</TD></TR><TR><TD CLASS="quote">i would say stick with 15s they are lighter and closer to stock dimensions so the speedo wont be to far off.</TD></TR></TABLE> well if you get the correct profile of tire then it will be the same diameter as stock. when i baught my car it came with 17 inch rims and 205/40/17 tires and they only threw the speedo off 3%. 103mph instead of 100mph isnt that big of a deal.
btw, im not suggesting 17's, im just clarifying that it is tire size, not rim size that effects the speedo and gearing.
Old Jan 16, 2005 | 08:15 AM
MarkJPana's Avatar
i would say that either rim will be fine, ill try to list the pros of each (altho thruout this thread it seems people have started it. i think as long as its tasteful and the tire size resembles the approximate size for stock (to keep the speedo accurate)
with 15s the wheel is generally going to be lighter, and tires are cheaper for them.
with 16s u get a nice big wheel, and you still wont have to go with rubber band tires if you choose. i tend to think that the 16" wheels are better looking in general, but thats just my opinion.
Old Jan 16, 2005 | 08:20 AM
kabaroo's Avatar
if you get 16's your speedo wont be off, if it is its barely noticable. my 16's w/ a 40 sidewall are a hair smaller than stock.
so 16 w/ a 45 side wall should work.
15's are nice too, i almost traded for some.
Old Jan 16, 2005 | 08:23 AM
Hapexamendios EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dstretch33 &raquo;</TD></TR><TR><TD CLASS="quote">get 20's Yo </TD></TR></TABLE> bling bling
Old Jan 16, 2005 | 10:08 AM
street dreams's Avatar
From: chillin in that city called queen creek, but homes the atl
Default Re: 15's or 16's (Hapexamendios EJ8)
do what u like
Forbesy's Avatar
I would say 15's....
My friend has a 4dr civic vti and usually runs 17's.... when he sent his rims off to get refurbished he borrowed a set of 15's from me and the differance was instantly noticable - better handling, faster off the mark, quicker through the gears etc! only downside is that his car is very low and with the 15's on it caused him a few problems with speed bumps and poor condition roads....
16's are a good compromise if you want looks as well as handling - but in the end the decision is yours as it is your car and your cash!
Old Jan 16, 2005 | 11:05 AM
Pythagoras's Avatar
i say 16's
Old Jan 16, 2005 | 11:16 AM
VTiVTo8000rpm's Avatar
24" $PinnAZ, MadD Bl!Ng$$$
*cough 15's cough*
Old Jan 16, 2005 | 11:44 AM
JDMish's Avatar
Default Re: 15's or 16's (VTiVTo8000rpm)
15's fo sho...
Old Jan 16, 2005 | 11:49 AM
Curve's Avatar
Default Re: 15's or 16's (smokee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smokee &raquo;</TD></TR><TR><TD CLASS="quote">i predict the consensus will say:
15's
