Hasport hydro tranny conversion with weld in mounts.
Old Jan 11, 2005 | 03:50 PM
Heavy Pee's Avatar
Default Hasport hydro tranny conversion with weld in mounts.
I have a CRX with weld in b series motor mounts. To use the hydro tranny conversion parts do I NEED to use the Hasport mounts along with it to work, or is seperate stuff that bolts onto the tranny?
Old Jan 11, 2005 | 04:19 PM
EL Vap133's Avatar
Default Re: Hasport hydro tranny conversion with weld in mounts. (Heavy Pee)
With the weld in mounts I am not sure what you can do, but someone has to know here.
Old Jan 11, 2005 | 05:04 PM
NCchris's Avatar
The only potential prob I can see would be that the B hydro tranny has a different mounting configuration than the B cable tranny. The mount plate that bolts on top of the cable tranny will not bolt to the hydro tranny without some work. The linkage should be no prob though. Also, the bolt holes on the rear bracket have to be drilled because the hydro tranny uses larger bolts.
HTH
chris
Down Shift Motoring
12
Feb 18, 2006 02:39 PM
limpy
Apr 25, 2005 05:22 PM
Lucias_D
Jan 16, 2005 09:24 PM
gsrhb7
Aug 9, 2004 12:52 PM
