Crank oil seal replacement
Old Jan 11, 2005 | 03:05 PM
alotawatts's Avatar
Default Crank oil seal replacement
Have a D16Y8. Can the crank oil seal be pulled and replaced without pulling the pump.......as in preventative maintenance along with timing belt change etc.
Yes I have Forum searched
Special tools required ?
Old Jan 11, 2005 | 03:10 PM
jlacoy82's Avatar
71.192.16.183
Default Re: Crank oil seal replacement (alotawatts)
Pump side of the motor? Or the other side?
Old Jan 11, 2005 | 03:17 PM
jlacoy82's Avatar
71.192.16.183
Default Re: Crank oil seal replacement (jlacoy82)
Nvm, I assume you meant pump side, as you didnt want to remove it.
Here are the directions from Helms, as part of oil pump service:
15. Remove the old oil seal from the oil pump.
16. Using the special tool ( Tool #: 07746-0010400 - Attachment, 52x55mm ), gently tap in the new oil seal until the driver bottoms against the pump.
NOTE: The oil seal alone can be replaced without removing the oil pump.
So essentially pull the old one out, tap the new one in flush with the lip of the pump, and your done.
Old Jan 11, 2005 | 06:15 PM
alotawatts's Avatar
Thanks ...except steps 15. & 16. are used (shown) with the pumpcase off the block.
I'm guessing the oil seal can be pulled with a seal puller or screws and the new seal seated back in with a long sleeve thats just the right diameter for the seal and reach / slip over over the crank-end.
Or will Tool #: 07746-0010400 fit over the crank ?
Modified by alotawatts at 7:37 PM 1/11/2005
Modified by alotawatts at 7:38 PM 1/11/2005
Old Jan 11, 2005 | 06:20 PM
_Cyclone_'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlacoy82 &raquo;</TD></TR><TR><TD CLASS="quote">Tool #: 07746-0010400 - Attachment, 52x55mm </TD></TR></TABLE>
Where do they sell tools listed in the Helms manual by these part numbers?
Old Jan 12, 2005 | 04:21 AM
EE_Chris's Avatar
Default Re: Crank oil seal replacement (CycloneBlue_1.6EL)
You can always buy the tools shown in the Helms manual at the dealership - after all, the Helms IS the factory service manual they use at the shop.
As for the front main seal - yes, it can replaced without pulling the pump. I had one distort on my D16Y7.
Old Jan 12, 2005 | 04:59 AM
spoonek9's Avatar
Why don't you just by a new oil pump, it comes with the seal installed already. Just a thought.
Old Jan 12, 2005 | 05:37 AM
mike1114's Avatar
Default Re: Crank oil seal replacement (spoonek9)
Oil pizzump is $192 from Acura for B18C, I'm looking for one right now someone might have bought but never used cause that is just waaaayyyyy to much!!!
Old Jan 12, 2005 | 05:55 AM
spoonek9's Avatar
Default Re: Crank oil seal replacement (mike1114)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike1114 &raquo;</TD></TR><TR><TD CLASS="quote">Oil pizzump is $192 from Acura for B18C, I'm looking for one right now someone might have bought but never used cause that is just waaaayyyyy to much!!!</TD></TR></TABLE>
Wow, you are getting screwed!!
Old Jan 13, 2005 | 04:32 AM
_Cyclone_'s Avatar
Retail sucks ***...
somick
Aug 15, 2017 08:14 AM
snatch
12
Mar 15, 2005 10:12 AM
NSTY Z33
Aug 4, 2004 10:55 PM
Mefain
May 16, 2003 09:02 AM
