need help. car is throwing check engine light.
Old Jan 11, 2005 | 12:09 PM
beat_nut's Avatar
Default need help. car is throwing check engine light.
99 honda civic ex. i was driving and my car seemed to be sputtering or misfiring. I kept on driving thinking it would go away. Then a spark plug flew out of my engine. it was still attatched to the plug but was just resting atop the hole. i was like 20 feet away from napa at this time when spark plug flew out of hole. I drove into nappa while spark plug was out. it sounded like this. WHAP WHAP WHAP.......I went into nappa and screwed the spark plug back in. It didnt go in that well, threads of head might be stripped but it went in and i started my car. It seems to be running well, no wierd noises or drop in power. But i am throwing a check engine light. What should i do?
Old Jan 11, 2005 | 12:16 PM
dantastic's Avatar
read the code (see sticky at top). then just reset the ecu. it'll probably go away.
Old Jan 11, 2005 | 12:56 PM
beat_nut's Avatar
Default Re: (dantastic)
my car is a 99 civic ex. Sticky at top is for 92-95
Old Jan 11, 2005 | 01:12 PM
beat_nut's Avatar
Default Re: (beat_nut)
help...
Old Jan 11, 2005 | 01:16 PM
dantastic's Avatar
read the thread: there's a link to obd2 codes (you'll need to borrow a code reader from an autoparts store). the codes indicated by the flashing check engine light are the same for obd2 cars, as is the procedure for jumping the 2pin connector
Old Jan 11, 2005 | 01:19 PM
beat_nut's Avatar
ohhhhh alright thank u
integratyper1990
Jul 18, 2011 01:48 PM
JDMJUNKIEMONKIE
Oct 22, 2009 09:24 PM
VtecCivic93
Sep 2, 2009 10:06 PM
Niskyspy
13
Mar 10, 2008 05:54 PM
sicx
Apr 16, 2004 09:38 PM
