civic plug wires
Old Jan 11, 2005 | 11:36 AM
terboracer's Avatar
Default civic plug wires
hi all. new member here. i was worried i might have damaged my sparkplug wires. i was pulling one of the wires to check for wear, but instead of disconnecting the plastic tube that attaches to the plug, I pulled a strip of rubber out of the top of the tube, and the connector stayed attached. i was worried i might have ripped the wire out, but i saw no metal wire inside the rubber. so i shoved the rubber back into the hole, and reattached the cap. the car started and ran normally, i dont think it has a cylinder out. did i rip the wire or not? i cant decide...
thoughts?
Old Jan 11, 2005 | 12:14 PM
snatch's Avatar
Default Re: civic plug wires (terboracer)
You would know if you were missing on a cylinder. It woudn't run 'normal'.
If you decide to replace the wires, just get stock OEM NGK.
I say run with it and see if it still works fine.
Old Jan 11, 2005 | 12:17 PM
toolowsol's Avatar
Default Re: civic plug wires (******)
The rubber boots are independant of the wire and connector, you justpulled the wire through the boot, no big deal
Old Jan 11, 2005 | 12:28 PM
flood's Avatar
Default Re: civic plug wires (toolowsol)
I noticed the above post says to use OEM NGK wires.
What about the NGK wires they sell on sparkplugs.com (or whatever that site is).
NGK Premium wire set 9486 HE76 $49.16
The pic shows them as blue. Will these work as well as ones bought from honda? They sell em for like 75bux a set.
Old Jan 11, 2005 | 12:32 PM
toolowsol's Avatar
Default Re: civic plug wires (flood)
yes, the aftermarket NGK's are just as nice as the oem plug wires but have blue shielding
Old Jan 11, 2005 | 12:38 PM
daily4dr's Avatar
if possible go with the oem black ones, their imo the best.
Old Jan 11, 2005 | 01:13 PM
flood's Avatar
Default Re: civic plug wires (daily4dr)
and what IYO makes them better? Is there actually a physical difference besides being black? Cause they are 25 dollars more, thats alot for a color choice.
Old Jan 11, 2005 | 08:38 PM
taz77's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by daily4dr &raquo;</TD></TR><TR><TD CLASS="quote">if possible go with the oem black ones, their imo the best.</TD></TR></TABLE>
i'll second this.
i got a few friends/co-workers at honda dealers who seen too many aftermarket wires including ngk's that goes bad and has yet to see one set of oem wires go bad. even afer 60k+ miles
Old Jan 12, 2005 | 05:48 AM
daily4dr's Avatar
honestly i don't know what the difference is technicaly, but everybody i run with uses the stock black wires and we're all running 400whp+ daily driven cars. just my opinion.
Old Jan 12, 2005 | 06:14 AM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ****** &raquo;</TD></TR><TR><TD CLASS="quote">If you decide to replace the wires, just get stock OEM NGK.</TD></TR></TABLE>
OEM Honda wires are made by Sumitomo, not NGK.
Old Jan 15, 2005 | 06:19 PM
itrhopeful's Avatar
Default Re: civic plug wires (Targa250R)
my oem wires went bad! and only after 236k!! what's up with that?!?!
Old Jan 15, 2005 | 09:40 PM
Mawk's Avatar
Default Re: civic plug wires (itrhopeful)
first off, its a cable, not a wire.. its literally a piece of string coated with copper so it wont produce a radio frequency, thats why theyre so sensative to bending. i dont see why you would be checking for wear? how could they possibly wear?
19da90
Feb 21, 2013 03:12 PM
hatch96y7
Jan 9, 2008 08:56 AM
be8teensee1
Oct 6, 2006 08:37 PM
jsrusse11
10
Nov 7, 2005 05:20 PM
TeamDOHCside
Dec 25, 2003 09:46 PM
