pm6 ecu rev limit
Old Jan 11, 2005 | 10:43 AM
slow91crx's Avatar
Default pm6 ecu rev limit
what is the rev limit on a stock pm6 ecu? mine rev limits at 7800 rpm and my friends exact same set up in his hatch only goes to 6800 rpm. we even switched ecu s in our cars and his still only revved to 6800. we also tried switching distributors with no different results. anyone have any ideas? thanks
Old Jan 11, 2005 | 11:13 AM
dvang's Avatar
Default Re: pm6 ecu rev limit (slow91crx)
sock tach is off
Old Jan 11, 2005 | 11:48 AM
90 Si Hatch's Avatar
Default Re: pm6 ecu rev limit (dvang)
i have an all stock 90 si hatch and my rev limit is 7200
Old Jan 11, 2005 | 11:59 AM
mrspeaker's Avatar
Default Re: pm6 ecu rev limit (White90SiHatch)
7200rpm when warm
6800rpm when cold
The stock tach is off by about 300-500rpm..
Old Jan 11, 2005 | 12:01 PM
UltimX's Avatar
Default Re: pm6 ecu rev limit (Mrspeaker)
Redline is 6800
fuel cutoff is 7100/7200
Old Jan 12, 2005 | 10:05 AM
slow91crx's Avatar
Default Re: pm6 ecu rev limit (UltimX)
the rev limit is 6800 in my crx wen cold and 7800 wen warm consistantly. in his hatch on more than one aftermarket tac his consistantly only hits 6800 warm or cold. why is this.
Old Jan 12, 2005 | 10:49 AM
fireant's Avatar
The cutoff is allegedly at 195°F where the rev limit raises from 6800 to 7200.
Maybe the problem is related to the thermostat.
Old Jan 12, 2005 | 10:33 PM
UltimX's Avatar
Default Re: pm6 ecu rev limit (fireant)
Where did you get the 195 degrees F?
Old Jan 16, 2005 | 05:02 AM
shorte's Avatar
The 91 pm6 has a slightly higher hot limit of about 7500-7600
only 91 though.
Old Jan 16, 2005 | 05:35 AM
Sikocivic's Avatar
Default Re: pm6 ecu rev limit (shorte)
My stock PM6 has no REV limit. It has never worked. I have run it up to 8000 and still did not did fuel cutoff. My chipped PM6 with TurboEdit works fine .
Old Jan 22, 2005 | 08:06 AM
rex88si's Avatar
My 88 SI only revs to 6500 warm or cold. it has the D16Y8 engine in it, and v-tec is activiated by a msd ignition switch. but i don't know why it only revs to 6500. maybe in 88 it would only rev to that? and then in later years it was raised?
i was just thinking of getting a PG7 ECU and have it rev to 7500. what do you think?
Old Jan 22, 2005 | 10:16 AM
mntuner2's Avatar
Default Re: pm6 ecu rev limit (Sikocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sikocivic &raquo;</TD></TR><TR><TD CLASS="quote">My stock PM6 has no REV limit. It has never worked. I have run it up to 8000 and still did not did fuel cutoff. My chipped PM6 with TurboEdit works fine . </TD></TR></TABLE>
TurboEdit, progStudio, hexed are my drugs of choice when modifing the pm6 box.
Old Jan 22, 2005 | 04:33 PM
UltimX's Avatar
Default Re: (rice_killer)
ricekiller: yes, 88 is special in that it has a lower redline. others have 6800 redline and 7100 cut stock.
Old Jan 22, 2005 | 06:05 PM
Mach69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shorte &raquo;</TD></TR><TR><TD CLASS="quote">The 91 pm6 has a slightly higher hot limit of about 7500-7600
only 91 though.</TD></TR></TABLE>
Is that true? Becuase if it is, I'm going to get one. I have never heard of that.
Old Jan 22, 2005 | 06:18 PM
trustnoone7935's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by White90SiHatch &raquo;</TD></TR><TR><TD CLASS="quote">i have an all stock 90 si hatch and my rev limit is 7200</TD></TR></TABLE>
mine too but it's not stock anymore
98greensi
Mar 5, 2012 04:07 PM
boostedNOTHARDLY
Dec 8, 2007 10:18 AM
thewrai6th
Aug 14, 2007 05:44 PM
CrxSiRyder
Apr 29, 2005 10:51 AM
SohcVtecCrix
Sep 14, 2002 07:23 AM
