bseries turbo manifold and 2.5" downpipe... CHEAP CHEAP CHEAP!
SOLD!
I used this setup when my motor was stock. I had ZERO problems with it. I guess this is one of the lucky ssauto manifolds. The wastegate has been rewelded so it is not going to fall off like all others. When I had the manifold I ran 9psi w/ a tial 38mm wastegate and it held steady, never had ANY boost creep. No signs of cracking whatsoever, I inspected it closely... if it was messed up I wouldnt be selling it. Fits all B-series, T3 flange and 35/38mm wastegate.
The downpipe is custom mandrel bent 2.5". Flange is 4bolt with compressor mounted on driverside. It is extended longer so you can use it w/o a cat and just bolt it to your exhaust. There is a small flat dent on the bottom. Has an o2 bung welded in the middle. I ran open downpipe for awhile with a different piece of piping, so it needs to be welded back together 5-10$ job at any exhaust shop.
The downpipe and manifold are made to go together so it will all bolt up to a bseries. however, I will seperate if no one wants them together. With this setup I made 294whp @ 9psi on a stock GSR motor.
Price is $175 + shipping. I have plenty of vouches, and ebay feedback of 128, and paypal verified. I am located in Poughkeepsie NY 12601 if anyone wants to pickup.
Modified by dunkd at 11:28 AM 1/19/2005
Charlie Moua
Oct 31, 2012 05:02 AM
99B16Si
Nov 17, 2006 06:27 AM
Timmay
Oct 22, 2006 10:49 AM
dunkd
Jan 10, 2005 11:16 AM
